I have a question on adding dissipation into the Lagrangian. On this page: https://profoundphysics.com/friction-in-lagrangian-mechanics/ the approach with adding an exponential factor to the Lagrangian is descibed. Starting with a lagrangian $L(\dot{q},q) = T(\dot{q}) - V(q)$, one can add an exponential damping factor: $L(\dot{q},q,t) = e^{ct}\left( T(\dot{q}) - V(q) \right)$. However, they claim that this only makes physical sense if one has "linear velocity dependent friction". I'm not sure of why this is the case though. From the Legendre transform $H(q,p) + L(\dot{q},q) = p \cdot \dot{q}$, I can take the gradient w.r.t. $p$, to get that $\dot{q} = \nabla_p H(q,p)$, with $H(q,p) = V(q) + T^*(p)$. (Here $ T^{\ast}(p) $ is the convex conjugate of $T$). In the case when $T(\dot{q}) = \frac{\lVert \dot{q} \rVert_2^2}{2}$, I think $ T^{\ast}(p) = \frac{\lVert p \rVert_2^2}{2}$, and in this case $\dot{q} = p$, and the friction term is linear and velocity dependent. For other kinetic energy functions $T$ this might not hold though. Does the approach with the exponential damping term only make sense "physically" when the kinetic energy is on this form (quadratic in $\dot{q}$)?
This could be the case, but only when equations of motion bear out such an interpretation.
In general, the equations of motion generated by your Lagrangian are: $$ c\frac{\partial T}{\partial \dot q}+ \frac{d}{dt}\frac{\partial T}{\partial \dot q}=-\frac{\partial V}{\partial q}\;.\tag{A} $$
Now consider a simple example case where the kinetic energy is a homogeneous function of degree 2 in the velocity: $$ T = \frac{1}{2}m\dot q^2 \tag{B} $$
Inserting Eq. (B) into Eq. (A) gives: $$ cm\dot q + m\ddot q = -\frac{\partial V}{\partial q}\;. $$
The term $$ -\frac{\partial V}{\partial q}\equiv F_{cons} $$ represents the conservative forces, by definition.
So, we have: $$ ma = F_{cons} - cm\dot q\;, $$ where the last term on the right is a linear function of the velocity or, if you prefer, a "linear velocity dependent friction."
For other kinetic energy functions T this might not hold though.
In general, for an arbitrary function $T(\dot q)$, you are correct.
However, in classical non-relativistic mechanics, the function $T$ is not completely arbitrary, but is defined in terms of cartesian coordinates as a homogeneous function of degree 2 in the cartesian velocity components: $$ T = \sum_{i=1}^N \frac{1}{2}m_i (\dot x_i^2+\dot y_i^2 + \dot z_i^2)\;, $$ where the sum is over the $N$ particles in the system. Therefore, we can say that, in cartesian coordinates, generally: $$ m \ddot x_i = -\frac{\partial V}{\partial x_i} - cm_i \dot x_i\;, $$ etc. for $y_i$ and $z_i$. So, that we can write: $$ m \vec a_i = -\vec \nabla_i V - cm_i\vec v_i\;, $$ for all of the $N$ particles indexed by $i$.
For any given physical system, you should just work out the equations of motion. For example, this might be the wrong interpretation when there is a velocity dependent potential. But, it seems to be a pretty good interpretation otherwise.
- 27,235
