Could a cold plasma be densified until its particles are so densely packed together that it behaves like a solid without reaching extreme temperatures? If so how?
Edit: okay there seems to be a confusion. I’m not trying to cool the plasma but simple push the particles so close together that they are equal in density to solids. There’s no reason it shouldn’t be able to do this and be still considered a plasma like substance because the moment the pressure holding it together (electromagnetic field) is relieved it goes back to classical plasma. I just want to know if increasing the density of cold plasma would make it hotter?
Ink
Plasma by definition is an ionized gas. Gas is fluid, so it will not behave like a solid. Above the critical temperature and pressure there is no real distinction between a gas and a liquid. Both are just a supercritical fluid.
Dale
  • 117,350
The center of the Sun is hydrogen at millions of degrees and extreme pressure. At that temperature, it is completely ionized. It is compressed to a density of 100 times that of water. It is still fluid.
If you cooled it to the point that it becomes solid (If it does. I don't know the properties of such a dense substance.), I expect it would not be ionized. Hence, not a plasma.
mmesser314
  • 49,702
Depending on the plasma temperature and the density, the plasma coupling parameter (ratio of potential energy to kinetic energy) is what determines wether the plasma should be treated as a classical or quantum, weakly coupled or strongly coupled. This is because if the plasma is very dense so that the average inter-particle distance is on the order of the de Broglie wavelength, then quantum considerations must be taken into account.
kstar
  • 35
