So I know a bird can stand on a power line without being electrocuted because there is no current going to the ground. However, I know that curents will pass to different electric potentials. My question is, if a bird has only one foot on the wire instead of two, would this open the current and allow the energy to build up inside the body due to it having a lower potential energy?
Mozibur Ullah
  • 14,713
You are confusing charge redistribution (things like static shocks) with continuous current flows in closed loop circuits.
If a bird stands on two feet with each foot on a different line, there is a potential and continuous current will flow zapping the bird. This is scenario is equivalent to a closed loop circuit.
If the bird stands on only one line, all feet can only touch the same potential so it makes no difference between one foot or two. There is no potential difference in the circuit so it doesn't matter whether it is one foot or two. This is like replacing the voltage source in a simple circuit with a 0V source (aka a piece of wire). It makes no difference whether you attach lots of wire loops to this 0V source or a bunch of dead end wires to it.
That said, to bring the floating potential of the bird's body to be the same as that of the line, there is still a momentary charge equalization between the line and the free space capacitance of the bird's body. For extremely high voltages lines, this charge equalization involves enough energy to cause harm, akin to a very strong static discharge. If I recall correctly, these high voltage lines start at 100kV, well beyond the 30kV voltage of your strongest static shock. Again, one or two feet does not matter here.
At these extremely high voltages, you can actually see the air around the lines glow in the dark as they ionize the air. So yeah, it's going to do something to a bird that touches it, and even do something to a bird before it makes physical contact with the line.
DKNguyen
  • 9,389
When a bird stands on a power line, it can do so without being electrocuted because the power line and the bird's body are at the same electrical potential. The bird's body acts as a conductor, allowing the current to flow through it without any buildup of energy or potential difference. Whether the bird has one foot or two on the wire doesn't affect the situation, as long as it's only touching a single power line. The principle of equipotentiality ensures that there is no voltage difference across the bird's body.
DrDark
  • 31
even a small amount of current flow (tens of milliamps) through a bird will kill it. Now when a bird stands on a power line with two feet, there is no current flow up one leg and down the other because the wire is a far better conductor of electricity than a bird is. this means there is essentially zero potential difference between the bird's feet, zero current flow, and it does not get electrocuted.
If the bird is big enough to touch two wires at different voltages, it will get fried like a ball of bacon.
niels nielsen
  • 99,024
