The Dirac current obeys a continuity equation
\partial_\mu({\bar\psi}\gamma^\mu\psi)~=~0,
which for electromgnetism we generalize $\partial_\mu~\rightarrow~\partial_\mu~+~ieA_\mu$ in a covariant manner. The $J^0~=~{\bar\psi}\gamma^0\psi$ $\psi^\dagger\psi~=~\rho$, which is the density. The spatial part is
{\vec j}~=~\psi^\dagger{\vec\alpha}\psi
The application of the momentum operator ${\hat p}~=~-i\hbar\nabla~-~ie{\vec A}$ gives a divergence of the 3-current
{\hat p}\cdot{\vec j}~=~i\hbar\big((\nabla\psi^\dagger)\cdot{\vec\alpha}\psi~+~\psi^\dagger{\vec\alpha}\cdot\nabla\psi\big)~-~ie{\vec A}\cdot\psi^\dagger{\vec\alpha}\psi,
where the spatial component $\alpha^i~=~\gamma^0\gamma^i$. This continuity equation tells us this equals $\partial\rho/\partial t$ and the quantum current divergence through a volume is equal to the rate the quantum density changes in that volume.
To consider the Bremsstrahlung question we need to address the force ${\vec F}~=~d{\vec p}/dt$ with respect to the current flow. The time derivative is evaluated with the Dirac Hamiltonian
H~=~{\vec\alpha}(\cdot{\hat p}~-~ie{\vec A}),
where the absence of mass should be noted. The time derivative is evaluated according to the commutator $[{\hat p},~H]$ and the calculation result in
\frac{d}{dt}{\hat p}\cdot{\vec j}~=~\langle F\rangle~=~e\langle{\vec E}~+~{\hat\alpha}\times\nabla\times{\vec A}\rangle.
The vector ${\vec\alpha}$ plays the role of a velocity of the particle, where the matrices are units in space with unit magnitude or $v~=~c$ in the Lorentz equation $({\vec v}/c)\times{\vec B}$.
So we have now that a massless particle which carries a charge will obey electrodynamics. Then what about the Bremsstrahlung? We can now use this to compute the energy of work of this force $W~=~\int\langle F\rangle\cdot d{\vec r}$ The power is the time derivative of this
P~=~dW/dt~=~\int\langle F\rangle\cdot d{\vec v}
We then consider the “c velocity” given by $\vec\alpha$ as a rotation given by the $SO(3)$ matrix elements $M$ that ${\vec\alpha}’~=~M{\vec\alpha}M^T$, where the time derivative on the velocity is due to a rotational $dM/dt$ and $dM^T/dt$. So the velocity is a particle at the speed of light moving in a circular path --- ignoring the electric field. This will then result in an acceleration $\dot a$ from the time derivatives of these matrices. At this point I am largely sketching this out but it is clear that a form of the Abraham-Lorentz force and Bremsstrahlung can be derived.
Rats, I see this has slit me from my previous identity here --- am back to 1.
