I had a question regarding gravitational potential energy and escape velocity. I don't really understand the concept of escape velocity. I have been learning it as the velocity required for an object to never come back to the planet, however, I don't understand how this works. Theoretically will it just keep moving forever? Why not for any other velocities less than the escape velocity will this work?
Along with that, I don't understand why at a distance of infinite the gravitational potential energy is 0 (I know it works for the equation $-\frac{GMm}{R}$ but I don't understand how it physically works)
And what about with respect to the planet? Say we considered the gravitational potential energy inside of a planet to be 0, then what would it be at a distance of infinite?
If you are familiar with work, the object does work on against gravity because its traveling away from Earth. This is the same as if a block is sliding through a surface with friction, it does work against the friction. The amount of energy the object has available do work to against a force is equal to its Kinetic energy. If the block starts off faster, it will take longer to reach a stop. The equation for work is $$W = \int_{\text{the path of the object}}{\bf F}\cdot d{\bf r}$$
and this makes sense because we are adding (hence integral) the amount of work done by the object when it moves an infinitesimal amount $d{\bf r}$ in the presence of force ${\bf F}$. There are sign conventions here that have been skipped over (i.e. what positive and negative work mean).
If you try to find how much kinetic energy you need to be able to do work against gravity all the way to infinty, you need to solve for $v$ here: $$\frac{1}{2}mv^2 = \int_{r_0}^\infty \frac{GMm}{r^2} dr =\frac{GMm}{r_0}$$ where I am assuming the object takes a path starting at $r_0$, so the surface. This solves to $v = \sqrt{\frac{2GM}{r_0}}$ and thus that is the velocity the particle needs to have enough energy to get to infinity, i.e. it will keep moving forever. If it has a lesser velocity, one can show it follows a parabolic path and falls back down (i.e. a regular person throws a baseball vertically up) and if it has a higher or equal velocity then it will have a hyperbolic trajectory and it will go to infinity.
Along with that, I don't understand why at a distance of infinite the gravitational potential energy is $0$.
This is a choice that we make. The potential energy could be written $-\frac{GMm}{r} + C$ for some constant $C$ and that would result in the same force of gravity (because the force is the derivative of the potential) and thus the same equations of motion for particles. Setting $C=0$ is a convention and the fact that we can change what it is is useful because then we can talk about potential energy relative to a point. Setting it to $0$ means we are comparing the potential energy relative to infinity. Setting $ C = +\frac{GMm}{r_0}$ would mean we are comparing potential energy relative to $r_0$. This is the same concept as how the formula $U = mgh$ (gravitational potential energy close to the earth surface) is dependent on where we set $h=0$. This is all because what matters is the energy difference (with respect to some point) and not the absolute energy.
And what about with respect to the planet? Say we considered the gravitational potential energy inside of a planet to be $0$, then what would it be at a distance of infinite?
Depends where. If we set it to $0$ at a point near the surface $r_0$, then $U(\infty) = +\frac{GMm}{r_0}$. The only place we cannot choose to set the potential to be $0$ is at $r=0$, the very center. This would not be useful because that would mean we would have to set $C=\infty$ which is not allowed or useful.
JohnA.
  • 1,793
Theoretically will it just keep moving forever ?
Yes. In the absence of interactions with any other bodies, an object with a speed greater than escape velocity will follow a hyperbolic path. Since this is an open orbit it will never return to the planet.
Why not for any other velocities less than the escape velocity ?
If an object is travelling at a speed less than the escape velocity, it will follow an elliptical (or possibly circular) orbit. Since these orbits are closed orbits it will eventually return to the point from where it started - unless it crashes into the planet first.
Why is the gravitational potential energy 0 at an infinite distance ?
This is a convention. Since we are only ever interested in differences in potential energy between one location and another, it does not matter where we choose to make potential energy equal to be zero. Putting the zero point for gravitational potential energy at infinity is convenient because it gives a particularly simple form for the formula for potential energy at other locations.
Say we considered the gravitational potential energy inside of a planet to be 0, then what would it be at an infinite distance ?
If we take the zero point for gravitational potential energy to be at some other location then we can work out the gravitational potential energy at infinity by calculating how much work we would have to do to an object starting from our new zero point to move it all the way to infinity.
gandalf61
  • 63,999
You can only deal with changes in the gravitational potential energy.
First consider throwing a ball of mass $m$ at a upward velocity of $v$ when you are close to the Earth.
The question is how high would the ball reach?
The "close to the Earth's surface" bit is there so that it can be assumed that the gravitational field strength $g$ is constant and so the change in gravitational potential is $m\,g\,\Delta h$ where $\Delta h$ is the change in vertical height.
Using the conservation of energy the change in kinetic energy plus the change in gravitational potential energy must equal zero.
$(\frac 12 m 0^2 -\frac 12mv^2_{\rm initial}) + (m\,g\,h_{\rm final} - m\,g\,0)=0$ as the final velocity is zero and the initial height is assumed to be zero and $H_{\rm final}$ is the height that the ball rises.
With a variable gravitational field strength $g= \frac{GM_{\rm Earth}}{R^2}$ the change in gravitational potential energy when a mass $m$ moves from a distance $R_{\rm initial}$ to a distance $R_{\rm final}$ is $\frac{GM_{\rm Earth}m}{R_{\rm final}}-\frac{GM_{\rm Earth}m}{R_{\rm initial}}$.
Again using the law of conservation of energy, $(\frac 12 m v_{\rm final}^2 -\frac 12mv^2_{\rm initial})- \frac{GM_{\rm Earth}m}{R_{\rm final}}-\frac{GM_{\rm Earth}m}{R_{\rm initial}}=0$.
Now make $v_{\rm final}=0$ and $R_{\rm initial} = R_{\rm Earth}$ so $\frac 12mv^2_{\rm initial}= \underbrace{\frac{GM_{\rm Earth}m}{R_{\rm Earth}}}_{\rm constant}-\frac{GM_{\rm Earth}m}{R_{\rm final}}$.
This relationship tells you that as you increase $v_{\rm initial}$, $R_{\rm final}$ also has to increase.
When $R_{\rm final} \to \infty$ then $v_{\rm initial} \to \frac{GM_{\rm Earth}m}{R_{\rm Earth}}$ and we call that final velocity, the escape velocity.
Farcher
  • 104,498
