The aberration of light will cause an observer to still see a black hole as "distant" when the event horizon is crossed.
This means that if the observer looks directly toward the center of the black hole, it will not encompass a proportion of their field of view approaching 50%; this limit instead occurs at the singularity.
It is supposedly difficult for an observer to actually determine when they have crossed the horizon, due to the equivalence principle implying that nothing special happens.
My friend and I are thinking that an observer could determine when they have crossed the event horizon based on how much of their field of view is taken up by it, assuming they have equipment with them to accurately measure angles. What would this proportion even be?
I have absolutely insufficient knowledge to determine this using general relativity and the like, so any reasoning below is almost certainly incorrect. All we did was play around with trigonometry for a bit.
An infinitesimally small observer, in a static spacetime, should see half of their field of view taken up at the surface of a sphere (like lying on the ground and seeing half of one's field of view being taken up by the sky, therefore making the ground also take up half). So the proportion of the field of view taken up is $1/2$, i.e., $\Omega=2\pi$. The subtension is therefore $\theta=\pi/2$, which can be proven with a simple drawing.
But, since the observer is not in a static spacetime, they're moving. We know that $\vert\mathrm{d}r/\mathrm{d}\tau\vert$ cannot exceed $c$ outside the event horizon, so it must happen inside it. We assumed it happens arbitarily close to it. Locally, spacetime is still flat, and the speed of light is still $c$ relative to the observer, so we figured that maybe the inscribed angle is equal to the correct angle at this point along the journey. That would be $\pi/4$ at the event horizon, which results in $\Omega=\left(2-\sqrt{2}\right)\pi$. This is just under 15% of the field of view, or more precisely, $\mathrm{hav}\,\pi/4$. Then, when the observer gets to the singularity, or right before rather, they should see half of their field of view taken up, i.e., $\Omega=2\pi$. The subtension is therefore $\theta=\pi/2$. This fits with our previous assumption because $\mathrm{hav}\,\pi/2=1/2$.
Is our guess of 15%, or exactly $\dfrac{2-\sqrt{2}}{4}$ anywhere close to the correct answer? Please also demonstrate the correct way to calculate this.
