Ok, so I was reading my book and there I found this statement:
We can conclude that the work done by static friction can be positive, negative or zero. When we consider the net work done by static friction at the contacting surfaces, since there is no relative displacement between the surfaces, the total work done by the static friction is zero.
However, I was not able to understand the above statement. Like, how do we identify where we can consider zero work by the static friction and where we cannot? Even if the surfaces are not slipping, there are cases where the static friction does some work, for instance, when the frame is accelerating.... Are there some other cases too where the work done by static friction is not zero?
Adhway
  • 410
Static friction does work if the material at the point of application of the force is displaced.
Consider a block resting on a rough surface. A horizontal force less than the maximum possible static friction force between the block and surface is applied to the block. It doesn’t move. No work is done by the static friction force between the block and the supporting surface.
Now consider a block on top of another block. A net horizontal force is applied to the lower block. Both blocks accelerate as one as long as the maximum static friction force between the blocks is not exceeded.
The only horizontal force acting on the upper block responsible for its acceleration is the static friction force applied to it by the lower block. Since that static friction force displaces the material at the point of application of the upper block in the stationary frame supporting both blocks, the static friction force does positive work on the upper block in the stationary frame.
Now consider the total work done by static friction between the blocks. The equal and opposite static friction force the upper block applies to the lower block, per Newton's 3rd law, does negative work on the lower block since the force is in the opposite direction to the displacement of the lower block. Since the displacement of both blocks is the same, the net work done by static friction between the blocks is zero.
Hope this helps.
Bob D
  • 81,786
Total work of static friction is zero. Taking 2 surfaces with no relative motion (since we're considering static friction), and exchanging equal and opposite friction force (by $3^{rd}$ principle of Newtonian dynamics), the total work reads
\begin{equation} \Delta W = \mathbf{F}_1 \cdot \Delta \mathbf{r}_1 + \mathbf{F}_2 \cdot \Delta \mathbf{r}_2 \ , \end{equation}
and since $\mathbf{F}_1 = - \mathbf{F}_2$ ($3^{rd}$ principle) and $\Delta \mathbf{r}_1 = \Delta \mathbf{r}_2$ (no relative motion), we get $\Delta W = 0$.
basics
  • 13,368
