In spherical Schwarzschild coordinates, it's $A \cdot B$ = constant. Is there something similar in the Schwarzschild solution in $(x, y, z, t)$ coordinates? For example in Droste coordinates $g_{tt} \cdot $det$(g_{ij})$ = constant?
The determinant of the metric tensor is a scalar density of weight 2. If I got it correctly that means that $($det$(Jac))^2 \cdot $det $(g_{\mu\nu})$ = constant. Since the determinant of the Jacobian of $(x, y, z, t)$ is 1, det $g_{\mu\nu}$ should be constant then. Is this reasoning correct? However, the determinant of this:
$$g_{\mu \nu}^\rm D=\left( \begin{array}{cccc} \rm 1-\frac{r_s}{r} & 0 & 0 & 0 \\ 0 & \rm \frac{r_s \ x^2}{r^2 \ (r_s-r)}-1 & -\rm \frac{r_s \ x \ y}{r^2 \ (r-r_s)} & \rm -\frac{r_s \ x \ z}{r^2 \ (r-r_s)} \\ 0 & \rm -\frac{r_s \ x \ y}{r^2 \ (r-r_s)} & \rm \frac{r_s \ y^2}{r^2 \ (r_s-r)}-1 & \rm -\frac{r_s \ y \ z}{r^2 \ (r-r_s)} \\ 0 & \rm -\frac{r_s \ x \ z}{r^2 \ (r-r_s)} & \rm -\frac{r_s \ y \ z}{r^2 \ (r-r_s)} & \rm \frac{r_s \ z^2}{r^2 \ (r_s-r)}-1 \\ \end{array} \right)$$
doesn't end up in something constant.
A Jacobian determinant is associated to a change of coordinates, not a single coordinate system, so talking about the Jacobian of a Cartesian coordinate chart doesn't make sense.
Albatross
  • 72,909
