The longer version of the question is: should we regard special relativity just as a spontaneous symmetry breaking phase of general relativity, driven by the non-zero vacuum expectation value (VEV) of metric which is acting as the Higgs field of gravity?
A side note added after seeing the answer and references provided by @Mitchell Porter: It seems that I am not the first one (too bad!) to investigate this idea of "metric as the Higgs field of gravity", though my version is a bit different since I am the first one (hopefully!) attempted to interpret the global Lorentz symmetry as similar to the global $SU(2)$ custodial symmetry in electroweak theory. A few quotes from some renowned gauge gravity experts:
- Trautman: "The metric tensor is a Higgs field breaking the symmetry from $GL (4,R)$ to the Lorentz group" in THE GEOMETRY OF GAUGE FIELDS
- Sardanashvily: "If gravity is a metric field by Einstein, it is a Higgs field" in Gravity as a Higgs field
This post is related to another PSE question on Gravity as a gauge theory. When gravity is expressed as a local Lorentz gauge theory (also know as Einstein-Cartan gravity), there are a lot of similarities compared with a typical gauge theory. For example, the gauge group of Lorentz gravity is the local Lorentz group $SO(1,3)$, and the gauge field of Lorentz gravity is the spin connection field $\omega^{ab}_\mu$. However, the metric $g_{\mu\nu}$ itself is not a gauge field in Lorentz gravity. Rather, the metric $g_{\mu\nu}$ is an add-on field in addition to the Lorentz gauge field $\omega^{ab}_\mu$ and there is no such add-on field in a typical gauge theory. Therefore, folks would usually point out that gravity, even in its Lorentz gauge theory format, is not comparable to a typical gauge theory.
But this point of view seems to be inaccurate. Let's take a look at the quintessential gauge theory: the electroweak theory of the standard model. Other than the electroweak gauge fields $W_\mu, A_\mu$, the electroweak theory has also an add-on non-gauge field: the Higgs field $H$ that are responsible for spontaneous symmetry breaking. Can we argue that metric is actually the Higgs field of gravity? Specifically, the symmetry-breaking add-on field of Lorentz gravity is the tetrad/veirbein field $e^a_\mu$ (which could be understood as the square root of metric $g_{\mu\nu} = \eta_{ab}e^a_\mu e^b_\nu$): the non-zero Minkowskian VEV of the tetrad/veirbein field $$<0|e^a_\mu |0> = \delta^a_\mu$$ or equivalently $$<0|g_{\mu\nu} |0> = \eta_{\mu\nu}$$ in Lorentz gravity breaks the gauge symmetry from the local Lorentz gauge symmetry $SO(1,3)$ down to the global Lorentz symmetry of special relativity, similar to the case of the non-zero VEV of Higgs field $$<0|H |0> = v$$ in electroweak theory breaking the gauge symmetry from $SU(2)*U_Y(1)$ down to $U_{EM}(1)$.
So can we really regard metric as the Higgs field of gravity? For more discussions over the similarities and dissimilarities between metric and Higgs field, see here, here, and here. See also here and here for discussions over the weird and peculiar state of global Lorentz symmetry as a combination of the residual elements from both the local Lorentz symmetry and the diffeomorphism symmetry, with tetrad/veirbein acting as the soldering form.
Added note to address @ACuriousMind comment:
The spontaneous symmetry breaking of the local Lorentz symmetry to global Lorentz symmetry is a complicated SSB process, which needs more explanation. To be exact, the standard model counterpart of the residual global Lorentz symmetry is actually not the electromagnetic $U_{EM}(1)$ symmetry. After spontaneous symmetry breaking, the residual global Lorentz symmetry in Lorentz gravity is more like the residual global $SU(2)$ custodial symmetry in electroweak theory. For how global custodial symmetry can survive SSB, please see details of global $SU(2)$ custodial symmetry in electroweak theory here: P. Sikivie, L. Susskind, M. B. Voloshin and V. I. Zakharov, Nucl. Phys. B 173 (1980) 189. Also see Wikipedia page here explaining custodial symmetry.
