I am now stuck on the impacts of choice of the coordinate system on the change in angular momentum and I would really appreciate it if someone can give me some help on this.
Consider the following example, there is a stick with mass $m$ and length $l$ which is initially at rest. Suppose a mass travels perpendicular to the stick and hits the stick at one of its ends in a very short time (then it disappears) and then the stick will have both translational and angular momentum.
However, I am very confused that if I choose the fixed point which coincides with the point of hit as the origin of our coordinate system, then the torque will be zero because the lever is $0$, which implies that the angular momentum will be conserved. Then after the collision, there is no external forces, and the angular momentum will be also conserved. In other words, the angular momentum doesn't change because the impact is so fast and I choose the point of impact as origin. I am wondering why this argument is not correct?
John
  • 133
When you choose the fixed point which coincides with the point of hit as the origin of our coordinate system, the angular momentum of the rod is $$\vec{L}= M (\vec{R}\times \vec{V}_{cm}) + I_{cm}\vec{\omega}$$ Where $\vec{R}$ is position vector of CM of the rod. These two will have to exactly cancel each other out to ensure $\vec{L}=0$ and angular momentum is conserved.
