Let's have two objects touching each other, i.e. me standing on the earth. We propel the smaller object directly away from the larger, i.e. I jump. The objects move apart, slow down and then return along the same path. According to Einstein, what's happening here is that the mass of the objects are bending space causing the straight line of my momentum to appear to bend in a 180 degree angle. However, because Einstein also says that this bending of space is happening in the forth dimension we can safely assume that we are not dealing with Euclidian geometry.
So according to the math what is that angle if not 180 degrees? Also that bend causes an acceleration of 9.8 m/s/s, correct? Would different angles change that acceleration? More precisely what is the relationship between the angle and the acceleration?
Bonus(?) question: What does that bend look like at a black hole?
