I understood, correct me if I'm wrong, that when you put a detector on the slits, electrons will behave like particles. Is it also true for photons?
EB97
  • 489
If you place a single-photon detector behind each slit, only one detector will register a photon for every photon incident on the slits. So yes, the photon behaves as an indivisible particle when one measures the slit through which it passes.
Aiden
  • 1,920
Photons and electrons are different. Just be aware that photons and electrons are always travelling with their wave properties. And much of their wave property nature is "virtual" ... for example an excited electron in an anode (about to be emitted itself) or in an excited atom (about to emit a photon) are already strongly interacting with the EM field long before their emissions occur.
An electrons virtually influenced path can be messed up after the slit by forcing it to reflect a photon ... it does not lose its wave properties it just gets new orders from the EM field .... thereby losing the effect of the double slit.
A photon however can only be absorbed if you want to detect it .... and poof its gone. Weak interaction is a method to observe many photons and try and get information about path by statistical means.
PhysicsDave
  • 2,886
