27
All real things have temperature. Temperature can be measured in various ways. We have reached to a great precision in measuring change in time and space , however I am not sure to what extent change in temperature can be measured? I searched the Internet but found no relevant results.
My question is : With what maximum precision a change in temperature can be measured ? Is there any limit to the measurement of precision in change of temperature ?
PS : I am getting suggestions that my question is probably a duplicate but here is the difference: I am not asking the minimum temperature attainable. I am asking with what maximum precision a change in temperature can be measured. For example - if I take two glasses of water ,or anything suitable ,under same constraints and heat them simultaneously and I stop heating one of the glass few seconds or minutes or hours before the second glass then there will be temperature difference. Now , How sensitive are our measuring instruments to measure the change in temperature? If I heat one glass for 30 minutes and second for 31 minutes or 30.5 minutes then say first glass will show temperature T and other glass will show T plus delta T, now , how fine the delta T can be ?
For a bulk substance under relatively normal conditions as you've asked about in your edited question, the "regular" standard is approximately a millikelvin (equal to 0.001 C) using platinum RTDs (resistive temperature devices, here is an example). I've also found this MIT PhD thesis (scroll down to get to the PDF, which also contains a summary of other high-precision temperature measurement techniques which you can read) which uses a laser interferometer to measure the change in level of a classical liquid thermometer and claims sub-microkelvin resolution. However, the problem with this is that it does not have sub-microkelvin accuracy - it can measure changes in temperature very precisely, but not absolute temperatures. In principle you could calibrate it to a known temperature, but it is very hard to get a temperature standard good to better than a millikelvin. The triple point of water (the temperature at which solid, liquid, and gas coexist) is only known to a precision of 0.1 mK.
So, in summary: the absolute temperature of an everyday substance can be measured to 0.1 mK at the very best, in practice more like 1 mK with significant effort. The change in temperature can however be measured with microkelvin resolution, if sufficiently isolated from the outside environment.
llama
  • 1,438
26
Lately, there's a lot of buzz around a research field called quantum thermometry. The goal here is to estimate the temperature of atomic systems close to absolute zero. This means finding out the exact temperature of super cold gases, electrons in superconductors, quantum dots, and a whole lot of other cool systems. At these tiny scales, quantum effects play a big role in how precisely we can measure. So, one of the things we're trying to figure out is the basic limits for temperature measurements in these quantum systems.
When we assume unbiased estimators, which means our temperature guesses average out to $T$, there's a cool rule that sets a limit to how accurate our guesses can be. This limit is called the quantum Cramér-Rao bound. This bound describes the minimum possible variance of an unbiased estimator for the temperature - basically, no matter how fancy our measurement tools get, we can't do better than this bound when trying to guess the temperature of quantum systems.
\begin{equation} \Delta T^2 \geq \frac{1}{n\mathcal{F}(T)}, \end{equation} where $n$ is how many times we repeat the measurement. The more times we measure, the better our estimate usually gets. The function $\mathcal{F}(T)$ is the quantum Fisher information. It's a measure of how much information we can squeeze out of our quantum system about the temperature. So, the right side of the equation gives us the best (smallest) variance achievable given the number of measurements and the informativeness of our system.
nanofarad
  • 103
Alex
  • 1,208
16
You have a nice answer about an engineering limit (millikelvin-ish) with a link to some primary literature which I have not read. But that's an engineering answer. A more interesting answer is whether there is a fundamental physical limit on measurable temperature differences.
Those of us who live in the macroscopic world tend to consider temperature as a continuous phenomenon. But our best understanding of temperature, for more than a century, is as a statistical phenomenon, relating changes in the internal energy $U$ of a system to its changes in its entropy $S$:
$$ \frac{\partial S}{\partial U} = \frac 1T $$
If you are unfamiliar with this fundamental definition, there are several minus signs and one-overs that you have to account for in order to recover the usual statement that heat moves from hot to cold in order to increase entropy. But the statistical nature comes from the definition of the entropy, $S = k\ln \Omega$, in terms of the number $\Omega$ of microscopic states with the same internal energy $U$, and the fact that the internal energy $U$ is itself quantized.
This statistical nature means in practice that there is no such thing as an extended object at a "constant temperature" which can be measured to infinite precision. You have comments which refer to temperature gradients and temperature drifts. But I'm talking about a temperature version of shot noise, where adjacent small regions in a bulk material have different temperatures just because energy and entropy come in lumps.
The size of the intrinsic temperature fluctuations will be larger for smaller subsystems and for lower temperatures. Some quantitative examples would be interesting to add, but I'll have to return later to do that (if there is interest).
rob
  • 96,301
Temperature is not a fundamental property, but a kind of average of the energy of a number of particles. Take for example a volume of gas. Within the gas there may be small temperature variations due to statistical fluctuations. The average of a larger amount of gas can be measured with greater precision than for a small amount of gas, because the statistical variation is greater for a smaller number of particles. This statistical nature of the property temperature, makes it difficult, if not impossible, to answer your question in an absolute way.
