For any potential energy function, there is an assumed zero. Potential energy is "unique" only up to an overall constant, because the force is equal to the derivative of the potential, and a uniform shift of the potential will therefore yield the same potential.
For $U = \frac{GMm}{r}$, the assumption is that we are using infinitely far away as our reference, i.e., we are saying that the potential is zero as $r\to\infty$. We don't have to do this, but it's a convenient choice, both mathematically and conceptually.
A small change in wording in the OP makes it clear how we should think about things in the linear case. Instead of saying height $h$, we will use position $y$ (or, more carefully, the vertical position $y$) of the ball. Then, the potential energy $U=mgy$ is a function of the position $y$ of the ball, and so the change in potential energy is $\Delta U = U_f-U_i = mgy_f-mgy_i$. Of course, this requires a choice of coordinate system, i.e., a choice of what $y=0$ means. It's often taken to be the ground, i.e., $y=0$ when the ball is on the ground. However, this is not necessary because not matter what, the change in potential energy is the same: $\Delta U = mg(y_f-y_i) = mg((y_f+y_0) - (y_i + y_0))$ so that if we move the origin by $y_0$, $\Delta U$ is the same. This effectively introduces a constant, physically irrelevant offset to $U$.
Finally, $U=mgy$ is an approximation that works when the ball is near the surface of the Earth. As OP mentions, the more correct expression for the potential is $U=-\frac{GMm}{r}$, where $r$ is the separation between the ball and the center of the Earth. However, near the surface of the Earth, the distance between the ball and the center of the Earth is
d = R + y\,,
where $y\ll R$, and $R$ is the radius of the Earth. In this case, we can expand $U$ in a Taylor series about $y/R=0$, yielding
\begin{align}
-\frac{GMm}{R+y} &=-\frac{G m M}{R}+\frac{G m M}{R^2} y -\frac{G m M}{R^3} y^2 + \cdots
\\&\approx
\mbox{constant} + m g y\,,
\end{align}
since $g=GM/R^2$.
Note that $mgy$ is easier to work with mathematically than $GMm/r$, partly because it leads to a constant force, and hence the equations of motion are easy to solve for (the constant-acceleration kinematic equations!). This is why we use $mgy$ when we can.
