Form what I understand if you have an equation such as:
$$v = v_0 + at$$
then the dimensions must match on both sides i.e. $L/T = L/T$ (which is true in this case), but I have seen equations such as 'position as a function of time' $x(t) = 1 + t^2$, and obviously time is in $T$, but apparently the function gives you position which is $L$... so what happens to $T$ and where does the $L$ come from? I thought dimensions must always match...
Also, let us say that you know the time to reach a destination is proportional to distance i.e. double the distance and you get double the time, now this makes sense to me, but as I said earlier I thought that dimensions must always be consistent or else you can not make comparisons in physics, so if you are giving me $L$ (the distance), how can that become $T$ (time) all of a sudden?
tpg2114
  • 16,815
fYre
  • 229
Units must always be consistent, that is correct. So using your example of:
$$ x(t) = 1 + t^2 $$
where the left hand side has units of $L$ (distance). This means the constant $1$ on the right side has implied units of $L$ while the coefficient in front of $t^2$ (which has the value of $1$) has implied units of $L/T^2$.
In other words, the units do match but they get attached to the constants multiplying each term.
tpg2114
  • 16,815
Write the function $x(t)$ in the form $$ x(t) = x_0 + v_0t + \frac12a_0t^2 $$ In the case you have given, then $x_0=1$, $v_0=0$ and $a_0=2$. Since $[v_0]=L/T$ and $[a_0]=L/T^2$, then the units match: $$ [x(t)] = [x_0] + [v_0][t] + \frac12[a_0][t^2] = L+\frac{L}{T}T+\frac{L}{T^2}T^2=L $$ The dimensions do indeed match, you are merely forgetting that the coefficients in front of $t$ (i.e., 1) have units as well (in this case, $L/T^2$).
Kyle Kanos
  • 29,127
