As I know Newton physics is used for most engineering, aerospace, mechanical, naval etc.
Where we must use Theory of Special Relativity and Theory of General Relativity to get correct results, only for astronomy, big distances/objects etc?
I'm going to add:
Space craft attitude control (star trackers). They account for stellar aberrations which are a form of the relativistic Doppler shift.
Radiation oncology uses the relativistic form of the Bethe-Bloch eq (1932): https://en.wikipedia.org/wiki/Bethe_formula
PET scans, since they involve annihilating your body's electrons with positrons it's inherently relativistic and quantum.
Einstein was so prolific, that by "Einstein Physics" you may be referring to three different things:
Quantum Mechanics - which was only started by Einstein but then fully developed by others (Planck, Bohr, Schrodinger, Dirac, Fermi, and many many others), is super-important in many areas of practical engineering, including the invention of the transistor in the 1940s which allowed modern computers, LED lighting, LASER (light amplification by stimulated emission of radiation), superconducting magnets, and a lot lot more.
The theory of special relativity effects calculation of extremely fast-moving objects, and isn't used for most "normal" engineering (e.g., isn't relevant when calculating trajectories of bullets or airplanes), but was very important for the development of the GPS (global positioning satellites) system. In the GPS system, we need to calculate the movement of satellites and electromagnetic beams coming from them very very accurately, to achieve good accuracy of the position on the ground. It turns out that without including special relativity (because these satellites are moving quickly around the earth), the calculations are not accurate enough.
It turns out that the GPS system also needs general relativity: Among other things, general relativity predicts that time slows down near a massive object. Because of general relativity, the time flows a bit more slowly on Earth than it does on the GPS satellites, and if this is not taken into account - the GPS calculations would not turn out to be accurate. Note that this is a separate effect than the velocity-related time dilation I mentioned above (due to special relativity), and both were needed to achieve good accuracy with GPS.
