When your covariant derivative of your 4-velocity is zero, you are in geodesic. Now, what if I measure your 4-velocity from a non-inertial reference frame, and see that it is constant with respect to me? You are clearly in a non-inertial reference frame, yet moving in a 'geodesic' as measured by me. A good example of it can be passengers with respect to an accelerating car. Isn’t that paradoxical?
Nayeem1
  • 1,306
In differential geometry, moving from an inertial to a non-inertial observer is just a matter of changing coordinates. It changes the metric and the Christoffel symbols that are used in the geodesic equation.
In the example of the accelerating car, being at rest inside it will not be a geodesic path.
A simpler example from differential geometry is to change from Cartesian to polar coordinates in the plane. The geodesic is a straight line for both cases, but it is simpler in the first one, with vanishing connections: $$\frac{\partial^2 X^{j}}{\partial \lambda^2} = 0$$
