I have seen the answer for related topics, and it makes sense to me for the trivial contranvariant expression for a vector, $$\pmb{v} = v^i\hat{e}_i\tag{1}$$ and it is said that if the base $\hat{e}_i$ double its length, the component $v^i$ should change contraryly to halve its length to make the vector invariant. However, the formal definition of contravariant vector by a transformation should be, $$x^{\alpha} \rightarrow x'^{\alpha} = \frac{\partial x'^{\alpha}}{\partial x^{\beta}}x^{\beta}\tag{2}$$ $$A^{\alpha} \rightarrow A'^{\alpha} = \frac{\partial x'^{\alpha}}{\partial x^{\beta}}A^{\beta}\tag{3}$$ It seems to me that, in formal definition, the component in contravariant manner would change corresponding to the change of coordinates since $x'^{\alpha}$ is in numerator in (3), isn't the component changing conversely to the change in coordinates? Please help me figure it out!
Asked
Active
Viewed 153 times
You're almost there, you just have the reasoning reversed. Suppose that $x'^\alpha = 2 x^\alpha$. Then all of the contravariant components double, just as you said. But a vector is left invariant because all the basis vectors become half as long. Formally, that's because the basis vectors carry a lower index. Intuitively, it's because a basis vector represents the distance you need to go to increase the coordinate by $1$. If you double the coordinates, then you only need to go half as far, so the basis vector is halved.
knzhou
- 107,105
