How does one interpret the relative motion of an object in orbit as it compares to to the object it is orbiting?
In flat spacetime, it's pretty easy to determine relative motion. If Alice sees Bob as traveling at 100mph, and herself as stationary - Bob sees Alice as traveling at 100mps and himself as stationary. It's perfectly reciprocal.
How does this principle work with gravity introduced?
Assume Alice is at the center of gravity of a large, non-rotating planet, and Bob is in a perfectly circular orbit:
1.) Alice can tell the distance to Bob.
2.) Alice can verify she is not rotating, and at what speed she would need to be rotating to keep facing bob.
Using the above two observations, Alice determines bob is moving at 100mph.
Now, Bob is under the impression he is in an inertial frame. Does Bob view Alice as moving at 100mph relative to him? Or does Bob view Alice as stationary? Intuitively, it seems like Bob would view Alice as stationary.
Which is the correct way to think about this?
EDIT FOR CLARITY:
More precisely, the combined formula for time dilation based on gravity and relative speeds can be written as:
(1−2GM/rc2−v2/c2)^(-1/2)
which reduces to: (1−v2/c2)^(-1/2) when gravity is not present
and reduces to: (1−2GM/rc2)^(-1/2) when relative motion is not present
so when Alice and Bob are calculating the rate at which they observe each other's time as passing, what v (velocity) should Alice record for Bob, and vice versa, in order for the formula to accurately match observations.
Please directly answer this portion of the question before explaining "why", to avoid vague explanations without a clear answer of which velocities should be recorded in order for the formula to match observations.
Assuming that Bob is not an idiot then he sees the planet that he is orbiting.
Both Bob and Alice are moving inertially. Both Bob and Alice can choose a reference frame where they are at rest. However, neither Bob's nor Alice's reference frames are inertial. In the presence of spacetime curvature there are no inertial frames (except as a local approximation).
Due to the spacetime curvature Bob and Alice are not equivalent observers. There is no symmetry expected between the two. Both can distinguish the directions towards the center and away from the center, and both know who is in orbit around the planet and who is not. More to the point, both will correctly predict things like the redshift or blueshift of signals sent between them.
Dale
  • 117,350
