Yang-Baxter Equation (YBE) seems to be a sufficient condition for integrability, i.e. if you have an $R$-matrix satisfying YBE, then the model is integrable. But how about the reverse? More specifically
  • Do all 1+1d integrable spin-chain models have an $R$-matrix satisfying YBE? I suspect the answer is no.
  • Consider integrable spin-chain models having discrete (say $\mathbb{Z}_2$, not a Lie group/Lie algebra) on-site symmetry, do these models have an $R$-matrix satisfying YBE? If yes, then how are those $R$-matrices related to the representation theory of quantum groups and vertex models, and if no, then what is the substitute for Algebraic Bethe Ansatz (Lax and $R$ matrices, and YBE) to study the origin of integrability of such models (I do not mean just constructing the conserved quantities)?
QGravity
  • 729
This is a hard question, and is closely related to what you precisely mean by (quantum) integrability. The definition that you use is sometimes called Yang-Baxter integrability: those models for which there is an underlying $R$-matrix obeying the Yang-Baxter equations - and a few other conditions, like a unitarity (aka inversion) relation $$R(x)\,R(-x) \propto 1 \, ,$$ and some sort of initial (aka regularity) condition that depends on normalisation $$ \text{e.g.} \quad R(0) = 1 \quad \text{or} \quad \mathrm{Res}_{x=0} \, R(x) =1 \, .$$ (I assume we are working with some additive parametrisation of the spectral parameter that I denote by $x$.)
Yang-Baxter integrability guarantees that the model has 'a lot of conserved quantities' and is 'exactly solvable'. (And then we have to make precise what we mean by those terms! But let me not go there now.)
So, "do all 1+1d integrable spin-chain models have an R-matrix satisfying YBE?" Well, yes if you mean 'Yang-Baxter integrable' (by definition), but not necessarily if you mean 'having lots of conserved charges': its a sufficient condition, but I do not think it's necessary, although I do not have a counter example.
Before I can answer the second question I'll need you to clarify what you mean by "having a discrete on-site symmetry". Do you mean that for each site we do not have a vector space (like $\mathbb{C}^2$ for spin-1/2) but just some discrete set, that is a representation of some discrete group? That would not really be a quantum spin chain. There does exists a notion of an $R$-matrix in the discrete setting, but I'm not an expert. The key word is "Yang-Baxter map".
Personally, by '(quantum) integrable' I always mean 'Yang-Baxter integrable'. But even then the details differ from case to case! Since I think this is less well known, and since I personally like this a lot (it's my research) let me illustrate this.
If you have such an $R$-matrix, then you can get a hamiltonian of an integrable model from the logarithmic derivative of the transfer matrix. The initial' = 'regularity' condition guarantees that there is a good value of the spectral parameter at which we can evaluate the logarithmic derivative, and (in the standard setting) that the result is local in the appropriate sense. Here the Yang-Baxter equation and unitarity guarantee that all other coefficients of $x$ in the transfer matrix (or its logarithm, or $\dots$) commute with the Hamiltonian. So we do indeed get a large family of commuting operators. This class of integrable spin chains contains the Heisenberg spin chain. For the Heisenberg XXX and XXZ chains (rational and trigonometric, resp), with six-vertex $R$-matrix, the eigenvectors can be constructed by algebraic Bethe ansatz. But for the Heisenberg XYZ chain (elliptic), with eight-vertex $R$-matrix, constructin eigenvectors is much more subtle since the magnon number is not conserved. There are two common ways around this:
  • If the length is even then you can use Baxter's face/vertex transformation to construct the ground state. This leads to dynamical R-matrices (of 'face = IRF = SOS type') and Felder's elliptic quantum group, where the Yang-Baxter equation is modified a little. I would still call this case 'Yang-Baxter integrable'.
  • You can also use Baxter's $Q$-operator to get the Bethe-ansatz equations without Bethe ansatz.
But it's instructive to consider another integrable spin chain: the Haldane-Shastry spin chain. It has long-range pair interactions mediated by an inverse-square potential: $$ H^\text{hs} = \sum_{i<j}^L \frac{1}{\sin^2[\pi(i-j)/L]} P_{ij} \, . $$ It is a truly remarkable spin chain, with high degeneracies and extremely simple energies (they're all in $\mathbb{Z}$ up to an overall normalisation constant) and (some) explicit eigenvectors. The high degeneracies are because the $SU(2)$ spin symmetry is enlarged to a Yangian symmetry, so there's certainly a rational $R$-matrix underlying this spin chain. But the Hamiltonian is not the logarithmic derivative of the transfer matrix! (For the interested: it's instead related to the so-called quantum determinant, which is why the model has Yangian symmetry. I can provide some references later in case someone is interested.) Moreover, the monodromy matrix is different than for Heisenberg XXX, even if it uses the same $R$-matrix. (The inhomogeneities are very different, not just parameters, but themselves nontrivial operators.) The point is: yes, the Haldane-Shastry spin 'has' an $R$-matrix, BUT it works in a different way than for Heisenberg.
Yet another interesting case is the Inozemtsev spin chain, which interpolates between Heisenberg XXX and Haldane-Shastry. It is exactly solvable (though much more complicated). The concensus is that it should be (quantum) integrable, but the underlying algebraic structure is not yet understood. (My collaborators and I are working on this question.)
