Here's a question inspired by Edward's answer to this question.
It's my understanding that the average energy density of a black hole in its rest frame is $\rho_\text{BH}(A)$, a function of surface area. I calculated $3c^2/2GA$ for a Schwarzschild black hole, but that's presumably not applicable here since I'm talking about an extended energy distribution. Anyway, suppose you are in a space filled with some sort of energy, matter, or whatever, which produces a potentially time-dependent stress-energy tensor. And further suppose that there is some finite, spherical region of surface area $A$ in this space, over which you measure the average energy density to be $\rho_\text{BH}(A)$, the net charge to be zero, and the total angular momentum of the matter within the region to be zero. (I'm assuming there is a measurement procedure available which can be carried out without entering the region, if it matters.)
Now, Edward's argument in the other question shows that there are at least two ways to produce that (average) energy density:
  1. The energy density arises from a fluid or other material at rest, such that the region is a black hole and there are no timelike geodesics exiting it
  2. The energy density has been "augmented" by a Lorentz boost from some other frame, implying that there are timelike geodesics exiting the region
Is it possible, in general, to distinguish between case 1 and case 2 by only looking at the other components of the stress energy tensor, without actually calculating the geodesics? If so, how? What would be the "signature" of a black hole in the components of $T^{\mu\nu}$ (or rather, their averages over the region in question)?
David Z
  • 77,804
David,
As you can see from Lubos's comment there is a serious flaw in the formulation of this question, so I will use this answer simply to explain some aspects of the topic. First the flaw:
the energy density of a Schwarzchild black hole
The Schwarzchild solution is a solution of the Vacuum Einstein equations ie $R^{u,v}=0$ and so $T^{u,v}=0$ ie the Stress Energy Tensor is zero throughout the Schwarzchild solution (removing the origin from this manifold avoids the undefinedness there). With zero stress-energy there are no fluids or local energy densities to measure or examine.
What is meant in the question (as it arises from the earlier Stack questions) has some relationships with the Hoop conjecture as Edward points out, but just for clarification I shall add more.
Let us not consider any more an Einstein vacuum and assume that some form of matter (or radiation - I will just say matter below) must have been present "originally". This matter is part of a non-vacuum solution of the Einstein equations, and so there will be a corresponding non-zero Stress-Energy Tensor whose matter is destined to become the Black Hole. So now the question begins to make sense.
So the question is really about what determines whether a given non-vacuum solution of Einstein's equations forms a Black Hole and whether this fact is measurable locally. The sentence that asks this is:
What would be the "signature" of the Black Hole in the components of $T^{u,v}$?$
I dont believe that this answer is known, partly because the space of all solutions of Einstein's equations is not yet known. If one considers the points made below, one might also conclude that GR alone was inadequate to predict the BH formation - matter properties are central too.
There are the classical Hawking-Penrose theorems which give a topological-geometric answer to this question by positing the existence of "closed trapped surfaces", along with certain properties of $T^{u,v}$. In that sense there is an answer, but it doesnt tell us when the closed trapped surfaces will form (generically).
Black Holes arose as physically plausible solutions to Einstein's equations because of the early work of Oppenheimer et al. Here there are two metrics combined to form the matter leading to a Black Hole:
Friedmann Dust (interior) + Schwarzchild (exterior)
(a clever trick to consider "massless dust" allows one to use only the Friedmann Dust solution). These two solutions need to be "glued together" to form the surface of the star. The $T^{u,v}$ (in the comoving frame and its translation into other frames) for this was given in Edward's earlier answer, and is non-zero in the star interior.
What causes another layer of complication in discussing the formation of Black Holes and Event Horizons is the teleological nature of their formation in General Relativity. This arises because "time" is just a parameter in the theory and the formation of the Black Hole is determined by the overall solution (thus in a time independent way). Now it has been concluded that for stellar objects of mass > TOV limit a Black Hole will form. But as remarked above translating this condition into a condition on the Stress-Energy Tensor alone may not be possible.
Physically one might expect that there is some local condition despite all these issues, such as the Hoop conjecture which includes the object's mass in its formulation. There are several subtleties connected with this unproven conjecture and one problem here is that "mass" is not a local property in GR (because mass = energy and the gravitational field contributes energy too, not just the Stress-Energy Tensor - hence we again may need the full solution of $G^{u,v}=T^{u,v}$.)
I shall add this link from Willie Wong for anyone interested in the latest on the Hoop Conjecture.
Finally my answer to the linked question might be of interest.
Roy Simpson
  • 4,791
Also, note that there are exact solutions of Einstein's equation that correspond to naked singularities. For an easy example, if you have a charged black hole with $Q>M$, there is no event horizon at all, but you still have a mass $M$ measured by an observer at asymptotic infinity. So, these solutions are a class of solutions that have "infinite" density at the singularity, but at the same time, aren't black holes.
It really is not a density. The critical spatial quantity is the Schwarzschild radius $R~=~2GM/c^2$, where the mass $M$ is contained in a volume with a radius $R$. The critical factor is not the amount of matter per unit volume, or density. A super massive black hole has a mass of 10 billion solar masses, and a radius 10 billion times the solar mass radius of 1.5 km. The volume in standard coordinates is $3.4\times 10^{30}km^3$. The sun has a volume of $1.4\times 10^{18}km^3$. !0 billion suns have a volume of $1.4\times 10^{28}km^3$. So 10 billion suns could be packed into the volume of a 10 billion solar mass black hole with room to spare.
