In the book "relativity" by Vincenzo Barone, the relativistic angular momentum tensor is defined as:
$L^{ij}= x^ip^j - x^jp^i$
(With the indexes $i,j$ going from 0 to 3)
And the relativistic torque tensor as:
$N^{ij} = x^iF^j - x^jF^i$
Where $F^\mu$ is the four-force vector.
Afterwards it states the equations of motion for $\mathbf L$ as:
$\frac{dL^{ij}}{ds} = N^{ij}$
But if you derive the momentum with respect to the path element d$s$ you should end up with four terms (two for each term of $\mathbf L$) of which two are those of the torque. So how do you prove such a statement.
Mauricio
  • 6,886
Andrea
  • 35
I don't know if I understand your last sentence correctly. $ds$ is a scalar and $L^{ij}$ is a rank 2 tensor (or rather the spatial components of one). So if you take the derivative of $L^{ij}$ with respect to $ds$, you will get another rank 2 tensor (or rather its spatial components). The proof that that rank 2 tensor is $N^{ij}$ is rather trivial (basically just the product rule): $d/ds (L^{ij}) = (dx^i/ds) p^j + x^i (dp^j/ds) - (dx^j/ds) p^i - x^j (dp^i/ds) $ $= u^i p^j + x^i F^j - u^j p^i - x^j F^i = x^i F^j - x^j F^i = N^{ij}$, since $u^i p^j - u^j p^i = u^i m u^j - u^j m u^i = 0$ by definition of $(p^i)$.
Tarik
  • 532
