I've built an optical spectrometer by following the instruction given on the Theremino website: Theremino_Spectrometer_Construction.pdf, but I'm having a little issue with it.
Everything works perfectly fine from UV to red wavelengths, but whenever I put an IR led in front of it, the light shows up at the extreme left side of the spectrum instead of the right side.
The diffraction grating I used is 1000 lines/mm and I'm expecting the IR light from the led to be around 940nm. I did remove the IR filter from the webcam lens.
I'm not sure if the issue is due to me incorrectly cutting the piece of diffraction grating, to reflections inside of the chamber or something else. I'm no expert in optics, so I hope someone with knowledge on the topic can give me a clue to what could be causing the issue.
