15
Reading various answers here ([1], [2], [3]), Wikipedia, nasa.gov, and other places, the common explanation of our blue sky is Rayleigh Scattering due to gases and particles in the air, maybe with some Mie Scattering thrown in, too. But then I found this discussion on a physics forum, and it reminded me of a discussion I had with a knowledgeable person a long time ago:
The basic premise is that it's not the individual molecules (mainly nitrogen, oxygen) that are responsible for the scattering, but rather the probabilistic fluctuations of the spaces between them.
Quoting from the end of that physicsforum.com discussion (and ignoring the somewhat spicy back-and-forth between the participants):
Condense air into liquid. It will have about thousand times MORE molecules per same volume. According to Rayley, etc there shall be thousand times MORE scattered light.
In reality it is way LESS.
The reason that Rayley formula (derived on the assumption that each molecule radiates incoherently from others) was originally considered as a satisfactory explanation, is that for an ideal gas mean of SQUARES of deviations (fluctuations) of number of molecules from the average for any given volume by chance coincides with the number of molecules in that volume. In the absense of those deviations scattering is zero (like in solids and to some degree in liquids).
I think first this was cleared by L.I. Mandelstamm in his paper "About optically homogenious and inhomogenious media" published in 1907.
This reasoning makes sense to me. If the N₂/O₂ molecules were the "particles" involved in Rayleigh scattering, then with twice as many molecules, we should have twice as much scattering. See other examples given in that discussion re: crystals and solids, too.
Indeed, even Einsein and Smoluchowski use density fluctuations as the explanation for blue sky.
Quoting from https://einsteinpapers.press.princeton.edu/vol3-doc/322:
Einstein's key insight in his paper was that the phenomena of critical opalescence and the blue color of the sky, which are not obviously related to each other, are both due to density fluctuations caused by the molecular constitution of matter.
Even after the paper's publication, however, the relationship between the two phenomena remained unclear to Smoluchowski. In 1911 he published a paper in which he claimed that the blue color of the sky has two causes: Rayleigh scattering by the molecules of the air, and Smoluchowski-Einstein scattering by density fluctuations.[16] Einstein immediately responded to this paper, pointing out that "a 'molecular opalescence' in addition to the fluctuation opalescence does not exist."[17] Smoluchowski readily accepted Einstein's criticism.
Another source: https://www.ias.ac.in/article/fulltext/reso/005/04/0037-0045
He [Einstein] realized that the fluctuations in density in the critical region would lead to the corresponding fluctuations in the refractive index of the medium. These refractive index variations would behave like atomic size scatterers and give rise to the scattering of light. If the fluctuations are large, the light scattering also becomes large
And one more, with more rigor: http://users.df.uba.ar/bragas/Web%20roberto/Papers/sobelman%20light%20scattering.pdf
Later on, when the concept of fluctuations was realized (Smoluchowski, Einstein), it became clear that the scattering in rarefied gases is determined by the fluctuations of density or the number of particles, i.e. by the quantity $\overline{\Delta N^2}$. But for an ideal gas one has $\overline{\Delta N^2} = N$, i.e. the result arrived at is precisely the same as in the consideration of the light scattering by individual particles.
So, as far as I can tell, this is the correct explanation. The Rayleigh scattering formula is not wrong per-se, but the "particles" involved are not air molecules, but rather thermal density fluctuations, which just so happen to have matching mathematical characteristics for an ideal gas to make the Rayleigh formula work as-is.
Yet on Wikipedia, we have (emphasis added): "The daytime sky appears blue because air molecules scatter shorter wavelengths of sunlight more than longer ones (redder light)...most of the light in the daytime sky is caused by scattering, which is dominated by ... Rayleigh scattering. The scattering due to molecule-sized particles (as in air) is greater in the directions ..."
So which is it?
Help me, physics.stackexchange — you're my only hope.
EDIT I also found this in a textbook scanned online:
This equation shows that the blue color of the sky is due to fluctuations in the density of the atmosphere...
Yet at the same time, the same text refers to fluctuation-based scattering as "Rayleigh scattering," which in most other sources I've found is a term associated with particle interactions, not fluctuations.
And another example: https://www.sciencedirect.com/topics/chemistry/rayleigh-scattering
Here, they refer separately to "the key role of fluctuations in RS [Rayleigh Scattering] from condensed media" and "particle RS," as if to indicate that the "Rayleigh" term applies to both, even though (as I understand it) Rayleigh's original model was just about particles, even if it accidentally also yielded the correct formula for the special case of ideal gases.
Bit of a mess of terminology...
jwd
  • 259
Well, this is not actually wrong. Molecules do scatter light, each molecule has a particular cross section. And this cross section is very small, so the dependence on wave frequency and scattering angle also follows the Rayleigh formula.
The light scattered by each molecule is subsequently scattered by the neighboring molecules, and then again and again; these fields all add up to yield the final scattered field. This is the microscopic description.
The total scattered field is the result of interference of all the $n$-times-scattered fields. It so happens, that when the medium is made of an ordered (periodic or quasi-periodic) arrangement of scattering centers (atoms, molecules, identical glass spheres etc.), we get only a few directions of scattering due to destructive interference in all other directions. Often these directions are the directions of the refracted and (if the light first meets an interface like vacuum-medium) reflected waves, sometimes diffraction can happen (again, on interface).
In a gas, since the positions of the scattering centers are uncorrelated, the $n$-times-scattered fields are also uncorrelated, and thus the addition of the $n$-times-scattered far fields can be viewed as incoherent, i.e. we can simply add intensities (rather than fields) and get the same resulting intensity.
This can also be described in a macroscopic way, by considering the macroscopic dielectric permittivity of the medium and its fluctuations. This will yield the result in terms of refractive index, rather than in terms of molecular cross sections. The end result will be the same.
I'm not so sure of very dense gases though. Maybe the assumption of total uncorrelation between the scattered fields of different orders (numbers of re-scatterings) would be wrong. Then, if singly-scattered amplitude appears to be comparable to that of the incident light (can such a gas even exist?), the result of macroscopic vs the naive microscopic computation would be different.
Finally, there seems to be some doubt in the OP as to whether Lord Rayleigh actually was naive enough not to understand the limitation of this approach. From his paper (ref. 1) we can see that he was fully aware of the requirement of total disorder for the addition of intensities to work:
We have no reason to suppose that the purest water is any more transparent than (14) would indicate; but it is more than doubtful whether the calculations are applicable to such a case, where the fundamental supposition, that the phases are entirely at random, is violated.
References
  1. Lord Rayleigh F.R.S. (1899) XXXIV. On the transmission of light through an atmosphere containing small particles in suspension, and on the origin of the blue of the sky, The London, Edinburgh, and Dublin Philosophical Magazine and Journal of Science, 47:287, 375-384, DOI: 10.1080/14786449908621276
Ruslan
  • 30,001
  • 70
  • 154
Interesting question.
The mean free path of air molecules at sea level is of order $\sim 10^2\rm\ nm$ (which I got confirmed from a vague recollection, but couldn't instantly reproduce using an online calculator). Since this is substantially shorter than the wavelength of light, $\sim 10^3\rm\ nm$, the scattering will be a wave phenomenon which interacts with many molecules at once, and the structure matters. The local changes in index of refraction due to thermal fluctuations are a good way to think of it. (Thinking about fluctuations is how Einstein argued that Brownian motion proves the atomic hypothesis: his least appreciated discovery from the "annus mirabilis" trio in 1905.)
The argument about compressing air into a transparent liquid is silly, because it neglects that structure matters. Consider that glass is transparent, but a pile of shattered glass is white. Or ice is transparent, but a pile of snowflakes is white.
It's not instantly obvious to me why index-of-refraction fluctuations give rise to the chromatic dispersion that makes air blue instead of red ... but this remark got too long for the comment box.
rob
  • 96,301
