I am trying to derive the change in entropy for a reversible process.
Let's say there is a body of mass $m$ with some specific heat that is heated reversibly from from a temperature $T_i$ to $T_f$.
Now, we know that the change in energy is $dE = TdS$. We also know that $\frac{dE}{dT} = MC$. Now, if I take $\frac{dE}{dT}$, I get $ dS+T\frac{dS}{dT}$.
Usually, however, I see that the final conclusion is $\frac{dE}{dT} = T\frac{dS}{dT}$. Where did the final $dS$ disappear?
reesespieces
  • 149
Now, we know that the change in energy is $dE = TdS$. We also know that $\frac{dE}{dT} = MC$. Now, if I take $\frac{dE}{dT}$, I get $ > dS+T\frac{dS}{dT}$.
I don't see how you got $dS+T\frac{dS}{dT}$.
If
$$dE=TdS$$ and
$$\frac{dE}{dT} = MC$$
it follows that
$$TdS=MCdT$$
or
$$dS=\frac{MCdT}{T}$$
Which is the same as the entropy definition (where $\delta Q_{rev}=dE$) of
$$dS=\frac{\delta Q_{rev}}T=\frac{MCdT}{T}$$
Then, after integrating, the change in entropy between the initial and final temperatures are
$$\Delta S=\int _{Ti}^{Tf}\frac{\delta Q_{rev}}{T}=\int_{Ti}^{Tf}\frac{mMC}{T}dT=MC\ln\frac{T_f}{T_i}$$
Hope this helps.
Bob D
  • 81,786
