This is a question more concerned about mathematical detail involving the Polyakov path integral.
In section $3.2$ of Polchinski's 1st String Theory book it is stated the following about Polyakov path integral:
The integral runs over all Euclidean metrics and over all embeddings $X^\mu(\sigma^1,\sigma^2)$ of the world-sheet in Minkowski spacetime: $$\int [d X \, d g] \, \exp (-S). \tag{3.21}$$
That the path integral is defined in the space of embedings $X: \Sigma \to M$ is clear for instance in Polchinski's Evaluation of the one loop string path integral and Nag's Mathematics in and out of String Theory.
However, there is a reference called Quantum Fields and Strings: A Course for Mathematicians. Volume $2$, whose section $1.4$, page $818$ has the following passage:
The Polyakov action leads to well-defined transition amplitudes, obtained by integration over the space $\text{Met}(\Sigma)$ of all positive metrics on $\Sigma$ for a given topology, as well as over the space of all maps $\text{Map}(\Sigma, M)$: We define $$\tag{1.5} A = \sum_{\text{topologies}} \int_{\text{Met}(\Sigma)} Dg \, \frac{1}{\mathcal{N}(g)} \int_{\text{Map}(\Sigma, M)}Dx \, e^{-S[x,g,G]}.$$
In the above quote, $x: \Sigma \to M$ is a map, $g$ is a metric on $\Sigma$ and $G$ is a metric on the target space $M$.
My question can be summarized in the following: what is the precise space of maps over which the path integral is defined? I've heard that the Polyakov path integral, as other path integrals, must admit "non-standard" trajectories i.e. maps that are not necessarily bijective, or whose differential is not injective, etc.
I'm really confused because the Polyakov classical action requires at least the maps $X^\mu$ to be differenttiable. Shouldn't the space of embeddings be more well-suited for this integration, from a geometrical point of view?
