A vector quantity has magnitude and direction. Pressure is force applied per area. Wouldn't that be the force having a direction towards the area? And 'as Newton came to realize, within the body of a liquid, pressure acts equally in all directions so that there is no resultant pressing in any direction.' Wouldn't that pressure applied on water and 'pressure acts equally in all directions so that there is no resultant pressing in any direction' just be on a plane that is bent, thus the direction are towards each area calculated towards all direction? And in terms of base quantities it would be kg/ms^2, containing meter in it. But other vector quantities contains meter at the top, does this explain why it is not a vector quantity? And if so how does it work?
The formula you are using is:
$P = |\vec{F}_\perp/A|$
You have to note that the force has a direction but so does the surface. When you define the pressure a force exert on a surface, you mean the intensity of the component perpendicular to the surface. If you want to take in account the other components you need an object with more components, called Stress Tensor.
I'll give you a visual reference for new people into the subject:
- 1,906
Pressure has units of force (mass times length divided by time divided by time) divided by units of area (length times length), but that is not exactly what it "is."
Generally, there are body forces (e.g., due to gravity) and surface forces. The surface force $\vec F$ on a small area $\delta A$, oriented in the $\hat n$ direction, can be written as: $$ \vec F = \vec \Sigma(\hat n)\delta A\;. $$
Following Batchelor "An Introduction to Fluid Dynamics" chapter 1, we see that the Sigma vector components must take the form: $$ \Sigma_i = \sigma_{ij}n_j\;, $$ where $\sigma$ is called the "stress tensor."
Following Batchelor, it can be shown that the stress tensor is symmetric. Further, it can be shown that, for a fluid at rest, the stress tensor can be taken as diagonal: $$ \sigma_{ij} = -p\delta_{ij}\;,\tag{fluid at rest} $$ where $p$ is the pressure (or "static-fluid pressure").
When a fluid is not at rest the stress tensor can have off-diagonal components, due for example to the viscosity and change in fluid velocity with respect to space. But the diagonal part of the stress tensor is still used to define the pressure as: $$ p = -\frac{1}{3}\sum_i \sigma_{ii}\;. $$
So, for example, if you are interested in a fluid at rest and want to determine the force on a small area $\delta A \hat n$ you use the equation: $$ \delta F_{i} = \sigma_{ij}\hat n_j \delta A = -p\delta_{ij}\hat n_j \delta A = -p\hat n_i\delta A\tag{fluid at rest}\;. $$ Or: $$ \frac{\delta F_i}{\delta A} = -p \hat n_i $$
In other words, the force indeed has a magnitude and a direction. The magnitude of the force is $p\delta A$ and the direction is opposite the unit normal that defines the small area of interest.
- 27,235
