I understand Gauss's law. I also understand that by gauss's law, for the infinite plate of charge(uniformly distributed), Electric field is the same everywhere which means it doesn't depend on the distance.
While I truly understand the proof of gauss's law and also its usage and proof why E is the same everywhere for infinite plane of charge, I can't still make sense of it logically in a physical sense.
Imagine there's infinite length of plate. Then, from it, at distance P, we know E is σ/2ε. But now, if we imagine the point from plate at distance P+100, we can easily see that there's higher distance between P+100 and each charge than it was for the point P. So the electric field definitely must be smaller, but it's not since however we proved it for point P, the same proof will give us exactly the same for P+100.
What am I missing in terms of logical explanation(no need to include formulas, I understand them)?
UPDATE
@J.Murray | @Jacob Stuligross, I think there're lots of approximations being made here.
we assume the ring can be rolled and used as a rectangle whose width is dx(the thickness of ring) and height as 2px(x is radius). x is definitely inner radius. Though, it quite won't be rectangle as if you say we got dx as thickness, then after rolling the ring, one height is x, second height is 2p(x+dx). So if you still treat it rectangle, we definitely lose some very small rectangle areas and are we sure it's so small charge won't be there ?
from the above point to the ring's points, cone is assumed to be drawn. While I agree that from apex to each point of the outer ring's edge, they're the same height(important since if not we can't treat it as if area * E_change holds true. if they're the same height, then true, all points of rings are distanced away from P by the same value, but this assumption means that there should not be multiple charges in the shell area(outer - inner). If there're more than 1 charge there, distance from it to our reference point wouldn't be the same as the distance between apex and outer edge. Hence calculation won't be fully correct, but since you bring dx there, i assume it's small, but still holds charges. if it holds multiple charges, it's bad. Any thoughts ?
