16
For example, if we really wanted to, could we, at least in principle, model electromagnetism just considering interactions between charged particles without using the EM field? That is, is it possible to predict all the same experimental results without bringing in the EM field (or the gravitational field, in gravitational theory, etc)?
For context, one thing I remember hearing several years ago is that, in general (this was in the context of classical physics), fields are essentially just a way of preserving locality -- of explaining how a particle at one location could have an effect on a particle at a different location. It was pointed out that that we could model these interactions without fields if we really wanted to, but the math would be a lot more complicated. Is that true? If so, would the math be fundamentally different, in the sense of having to invent a whole new framework with different mathematical objects, or would the calculations just be a lot more involved?
The analogy that comes to mind is that of virtual particles vs actual particles -- if I understand correctly, the former are a handy bit of math that make certain QFT calculations much easier, but aren't actually necessary in order to explain anything, whereas the latter are needed in order to explain various observable phenomena. Are fields more like the former or the latter in that sense?
To be clear, I'm not trying to suggest that doing away with fields would be a remotely good idea, regardless of whether they're entirely necessary or not, since they're clearly useful.
Edit: Also, to be clear, I'm not asking about the mathematical definition of fields, as I already understand that. Nor am I asking about whether fields "really" exist, in the sense of corresponding to some sort of physical object, as that opens a whole can of worms about whether anything unobservable in physics "really" exists, which is an unsolved question in philosophy of science. I'm purely asking about whether fields are mathematically necessary to make all the same predictions, without inventing an entirely new mathematical framework.
psmears
  • 334
6 Answers6
14
The analogy that comes to mind is that of virtual particles vs actual particles -- if I understand correctly, the former are handy bit of math that make certain QFT calculations much easier, but aren't actually necessary in order to explain anything, whereas the latter are needed in order to explain various observable phenomena.
I would take issue with that. If you are doing perturbative QFT, then you will be summing up terms in order to compute physical quantities (cross sections, decay rates, etc). Whether you want to associate those terms with cute little diagrams and wrap flowery language like "virtual particle" around them is a matter of personal taste, but they aren't a handy tool - their existence is fundamental to perturbative QFT.
And in fact, my previous paragraph is quite analogous to what I'd say about electromagnetic fields. Would it be possible to compute forces between particles without explicitly referencing an electromagnetic field? Yes. But it will be unpleasant - the force on one particle right now will depend on the state of motion of every other particle at various different times in the past. Momentum and energy would no longer be locally conserved. Actually computing the force on a charged particle would require you to do calculations which are mathematically identical to solving Maxwell's equations (since after all, they are what govern electromagnetism), so there's simply no point in it.
To illustrate the idea, imagine running a computer simulation of a handful of charged particles which interact electromagnetically. With clever choices of plotting scheme, you could watch particles accelerate and release radiation which subsequently affects the motion of the other particles when it arrives at their position. By watching the delicate interplay between the particles and fields, we can make sense of how they move.
Now simply stop printing out the electromagnetic field variables. Now you see particles moving around while making seemingly random movements - they slow down (or start moving) unexpectedly based on no locally identifiable cause. After a while, you start to realize that the forces on the particles don't depend on where the other particles are and what they're doing at that moment - they depend on where they were and what they were doing some time before, with that time delay being proportional to the distance between them.
Clearly we have the capability of formulating these forces without thinking about field theories - our simulation can do it, after all. But when you dig into it, the calculations it does to compute and keep track of all of those forces is precisely what it needs to do to solve a field theory, so by forgetting about the $\mathbf E$ and $\mathbf B$ degrees of freedom you are doing little more than making the universe more philosophically confusing while gaining precisely nothing from a calculational standpoint.
Albatross
  • 72,909
13
Electromagnetism can be done without fields, or more precisely without fields as independent degree of freedom. The idea here is that the field is only generated by charges and it is only felt by charges, so if a charge $q_1$ is at the origin at time $0$, and another charge $q_2$ is at distance $r = ct$ from the origin at time $t$, then $q_2$ will feel a force due to $q_1$. This force can be written explicitly in terms of the Liénard–Wiechert potentials which are functions of the distance and velocities of the particles only.
The problem with this approach is that to describe any particle's motion at any time $t_0$, we need to know all particles which were at distance $c (t_0 - t)$ for all times $t < t_0$. In other words, we'd need to solve the equations of motion given boundary conditions on the light cone. The approach can be formally developed and is known as Feynman-Wheeler electromagnetism (NB: the Wikipedia article really doesn't give much detail at all, the original paper is Rev. Mod. Phys. 21 (1949), 425).
In the usual description, we introduce the fields, and they simplify the boundary conditions: giving the values of the fields at time $t_0$ in a small neighborhood of our particle allows us to predict its motion.
So in that sense the fields are not necessary, they just allow us to work with more convenient boundary conditions. Of course, the introduction of the fields as independent degrees of freedom adds so much power to the theory that we really don't want to give up the fields. Imagine having to describe you radio reacting to the electrons in the antenna in the radio station instead of just thinking about the FM wave arriving, and how it's picked up by the antenna.
tobi_s
  • 1,321
11
Say for the purpose of OP's question that we are only interested in describing the phenomena of matter and not the fields. Given a local field theory, one can of course integrate out the fields to get the corresponding non-local direct interparticle action.
The issue is the opposite: If we have given up the principle of locality, there are infinitely many non-local direct interparticle models that one can propose, and it's unclear which one is the correct in order to make accurate predictions, cf. OP's title question.
Light is an electromagnetic field. Our eyes detect light. We don't need to go through a calculation to determine what we see. So, unless you want to go into some philosophical discussion about what it means to "see" something, I would say light is real and therefore fields are real. It would be unthinkably difficult to explain the effects of diffraction and all that if we cannot talk about light itself.
flippiefanus
  • 16,824
Field theories are often a resort after realizing you cannot work with $10^{23}$ particles...
For the example of electrodynamics, just take any continuous charge distribution, say a charged spherical conductor. How would you be working with the ridiculous number of charged particles in it individually?
Or take the example of deformation of or sound propagation in a solid. You could do it using a lattice theory, but (perhaps after homogenization) instead you can use the continuous description in elasticity, i.e. a classical field theory. High-dimensional vectors and matrices can be much less convenient than functions and PDEs...
And so yes, frameworks differ (although there are mathematical analogies, of course), you might find yourself choosing between analysis and linear algebra.
kricheli
  • 3,310
Are fields theories necessary to make accurate predictions...
No, they are not necessary to make accurate predictions.
The behavior of a hydrogen atom is predicted pretty accurately via the Quantum Mechanics of a single particle in a potential $e^2/r$.
The behavior of a block sliding down a ramp is predicted pretty accurately via classical Newtonian mechanics.
or do they just make calculations easier?
Sometimes they do, sometimes they don't.
hft
  • 27,235
