Force is defined by acceleration , and acceleration requires the determination of" inertial frames".
But an inertial frames also requires the knowledge of forces which requires measuring acceleration, but with respect to what ?
Gauge
  • 103
acceleration requires the determination of" inertial frames" .
That is not correct. In modern physics there are two distinct concepts of acceleration. Neither requires the determination of an inertial frame.
Proper acceleration is the acceleration measured by an accelerometer. It is an invariant quantity, so it is the same in any frame whether inertial or not. Proper acceleration is one of the particularly important concepts because it is experimentally measurable.
Coordinate acceleration is the second time derivative of position in some specified reference frame. It obviously is frame dependent, but it is not required to identify whether the given frame is inertial or not.
Dale
  • 117,350
The direct way to measure force is a force gauge. A force gauge is a spring whose extension you measure. No acceleration involved.
John Doty
  • 22,119
