Recently I read some article about vacuum and negative pressure, and the reasoning was like this:
Assume you have a vacuum in a cylinder, and then you move the top of the cylinder (like a piston) up to create negative pressure.
That made me wonder: Does a real vacuum exist actually? I mean: I you pump 1 liter of air from a cylinder containing 1 liter of air, do you have the perfect vacuum? Or does it mean that after having extracted half a liter of air, then there is only half a liter air air in the one liter container? If so, extracting another half a liter of "air" you actually extracted a quarter liter of air (at the average)? So there would be increasingly less air in the cylinder, but you will never reach the perfect vacuum while extracting only a finite amount of "air".
And if you don't have a perfect vacuum, the pressure won't be zero, so if moving up the piston, it would just reduce the remaining pressure, but never create a negative pressure. Likewise even in the depth of space there would not be a perfect vacuum, as a few gas molecules or atoms are surely around somewhere.
Is that true?
U. Windl
  • 101
