I have just started to study canonical transformations and I am trying to solve this exercise. Given the following canonical transformation for $Q$, $$ Q = q^{-2} $$ I have to find the corresponding canonical transformation for $P$. The determinant of the matrix $$ M = \begin{pmatrix} -\frac{2}{q^3} & 0 \\ \frac{\partial P}{\partial q} & \frac{\partial P}{\partial p} \end{pmatrix} $$ has to be $1$, from which it follows that $$ \frac{\partial P}{\partial p} = -\frac{q^3}{2} \iff P = -\frac{q^3p}{2}+k(q)$$ My question is: can I just take $k(q)=0$ to solve the problem or is there a unique canonical transformation given that $Q$? Are there any more conditions that $P$ needs to verify in order to be the requested canonical transformation?
David
  • 111
TL;DR: The answer depends on the context.
Examples:
  1. If we assume that a canonical transformation here means a symplectomorphism, then indeed OP's method is correct: the determinant of the Jacobian is 1, and it is easy to check that OP's solution is a symplectomorphism. We should keep the "integration constant" $k(q)$, which may be determined by possible further conditions.
  2. If $q\to Q=q^{-2}$ is viewed as a point transformation of the base manifold $M$ of a cotangent bundle $T^{\ast}M$, then the momentum transforms as components of a covector $$ p~=~\frac{\partial Q}{\partial q}P~=~-\frac{2}{q^3}P,$$ i.e. $k(q)=0$.
