I'm trying to use a Peltier module (e.g. TEC1-12703) for heat diffusion physical experiment. An external power source provides around 8V with 1A current, so the generated heat from the surface of the module is quite good and very hot to touch.
However, when attaching a thin aluminum foil of 7cm x 7cm (with a thermal paste) to the hot side, only the part that is directly connected to the module becomes hot, but heat is not spread around at all (maybe only very very close to, ~5mm). It would be expected to receive a diffusion effect so that the foil will become hot until equilibrium is reached, since the Peltier module pumps heat all the time.
What am I missing? Is it because the foil is too thin so heat is dissipated so quickly?
[Edit on May 8th, 2023]
Following @john-doty answer below, few further questions come to my mind:
  1. Can I compute the rate by which heat is removed from the foil and what is the necessary heat power input (Watts) to overcome this effect? Where can I find typical constants for a thin aluminum foil? (assuming no airflow is forced upon)
  2. Is there a better electrical device in the form factor of a small Peltier module that could pump more energy into the foil?
Thanks, Moti.
Moti
  • 23
If the foil is thin, air will efficiently remove heat from the foil, while heat will only diffuse into the foil slowly. The cross sectional area for cooling is the area of the foil, while the cross sectional area for heating is the thickness of the foil times the circumference of the heater.
John Doty
  • 22,119
