Take a cupboard or just a large wooden box. When pushed it a point above its center of mass, the cupboard topples because there is a net torque due to the friction and the force you apply. When pushed at a point below the center of mass, the cupboard does not as the torque due to the friction and the torque due to the force you apply are in opposite directions (they cancel). Now my question is if the force you apply is equal to the maximum value of static friction, then the box is at rest. However, since the friction applied is at a larger distance from the center of mass than your force, shouldn't there be a net torque?
Asked
Active
Viewed 49 times
