I was watching a video describing a way to deduce Newton's Third law using symmetry considerations.
Consider a system of $N$ particles not acted upon by any external force (isolated system). Suppose the medium in which the system in placed is homogenous.
Now we are displacing each particle in the system simultaneously and in the same direction such that the configuration of the system remains the same.
Now it has been said that the displacement which we have done is instantaneous i.e., there is no time interval involved in making such displacement. So it is just a thought process. Such displacements are known as virtual dislacements. So, there is no question of what agency has brought out this displacement.
Now we are trying to find out the virtual work done by the internal forces (as external force = $0$)
It has been said that $\text{Virtual work done}\;=\;0\tag{1}$
So, $(\sum_i\vec F_i).\vec{\delta s}=0$
As the above equation holds for all $\delta\vec s$
By Newton's second law,
$\frac{d}{dt}\sum_i\vec{p_i}=0\implies\frac{d}{dt}\vec P=0$
So, total momentum is conserved.
If we have two particle system, then
$\sum_{i=1}^2\vec F_i=0\implies \vec{F_1}+\vec{F_2}=0$
Thus, proving Newton's Third Law.
I have a doubt that the proof relies on $(1)$. I am not able to understand how $(1)$ is true?
In Goldstein's Classical Mechanics, momentum conservation has been proved through virtual work but by considering $(1)$ as a consequence of Newton's Third Law.
But here, I am not able to understand how we are considering $(1)$ to be true? I am not abe to understand that.
Iti
  • 456
By the work-energy theorem, the amount of work done to a system equals the increase in its mechanical energy. However, after performing a virtual displacement, the system is in exactly the same state, only at a different point in space. Thus its mechanical energy must be the same before and after the virtual displacement (assuming only the homogeneity of space). This can only be so if the work done in displacing the system is zero.
Jakob KS
  • 2,559
