I am studying the phenomenon of pair production and I learned that it cannot occur in a vacuum. Rather it occurs near a nucleus which absorbs momentum to keep the momentum conserved.
Instead of a nucleus, can we have pair production with two photons? For example, the two photons collide to produce an electron-positron pair.
cconsta1
  • 1,257
Yes the process you are saying is absolutely possible $$\gamma + \gamma \rightarrow e^+ +e^-$$ Is a lowest order process that can occur in QED, since it involves two vertex, and as you know the QED respects time reversal or t-parity the process
$$ e^+ +e^- → γ +γ$$ must be time reversal.
EDIT: Pair Annihilation the process may be interpreted as a incoming photon giving a positron and an electron and one of them absorbing another photon for momentum corrections in that case one of the fermion will become a propagator.
Just hold your screen upside down (reverse time direction) and you'll see the process just replace the $e^-$ and $e^+$ accordingly.
For more details refer to Chapter 9 of Lahiri & Pal A first book of Quantum Field Theory
