This is a very simplistic view from an interested structural design engineer (retired).
Mass curves space. Taking the case of a sphere of uniform density the point at which you have as much mass outside as inside is a spherical shell two thirds the radius of the sphere. Therefore, once you pass through that shell closer to the center should not the curvature of space reduce rather than increase since most of the mass is outside? If so a singularity at the center could not occur. The maximum curvature of space would be a 2D spherical shell not a singularity. Clearly a black hole may not be a uniform density, but even if it increased exponentially, the point at which there would be as much mass outside as inside would still be a 2D shell of some radius. Why is this not the case please.
A black hole is not like a planet or a star, it does not have any volume filled with mass, all its mass is concentrated in a single point. We can talk, for example, about Schwarzschild radius of a black hole, but it doesn't mean that the black hole is a sphere of Schwarzschild radius filled with matter. Whatever positive radius $r$ you choose, the mass of the matter outside of the 2D sphere with radius $r$ is zero, the whole mass of the black hole is located at a single point at $r=0$. That's what is called a singularity - an infinite density.
If a black hole was a sphere of a uniform density then the curvature would indeed decrease as you approached the centre and would indeed be zero at the centre. This geometry is called the Schwarzschild interior metric and in fact exactly this issue is discussed in my answer to What is the general relativity explanation for why objects at the center of the Earth are weightless?
However a black hole is not a uniform sphere or even a sphere with a varying density. The event horizon is not the surface of the black hole. It is just a place in space beyond which light can no longer escape. The black hole is actually all just a vacuum except at the singularity at the centre (where the geometry is undefined) so no matter how close you get to the singularity all the mass of the black hole is still below you. That's why the curvature keeps increasing the farther towards the centre that you go.
John Rennie
  • 367,598
