43
The sun sends out unpolarized light. There are infinite degrees in which these photons are oriented. A polarizer only lets in light of one specific orientation.
In statistics, the infinitesimal area/slice of a single value in a continuous probability distribution is virtually meaningless, but I'll call it zero.
How can there be any light coming through a polarizer if only a 'slice' of the continuous circle of orientations is being allowed through? Is it that the polarizers allow light within a certain degree of deviation of that orientation?
Sandejo
  • 5,496
5 Answers5
44
A polarizer is not a gatekeeper that lets correctly polarized photons through and says "you shall not pass" to incorrectly, or halfway-correctly polarized ones. It interacts with each and every one of them.
Any passive optical device (such as a polarizer) has an effect on the light by absorbing and re-emitting photons. Incoming photons interact with the polarizer (which may be an anisotropic crystal or a wire grid or whatever) by "jiggling" the charged particles (mostly free and bound electrons) it is made of back and forth.
If we have a perfect polarizer, photons that are polarized 90 degrees to the polarizer will always be absorbed and, possibly, reflected or deflected. But when struck by any other photon there's a non-zero chance of re-emitting a photon travelling in the same direction, but polarized parallel to the polarizer.
LLlAMnYP
  • 1,638
  • 14
  • 15
29
A polarizer passes the component of the incident light that is aligned with its axis of polarization.
Any polarization that is not perfectly perpendicular to the axis of polarization has a non-zero component parallel to the axis.
Net result, the intensity of the transmitted beam, for an ideal polarizer and a linearly polarized input, is $I_0\cos^2\theta$ where $I_0$ is the intensity of the input beam and $\theta$ is the angle between the axis of the polarizer and the E-field polarization of the beam.
The Photon
  • 29,651
23
Are you familiar with the rope in a slit analogy for polarization?
Rope sits in a vertical slit. If you wobble it left-to-right, the wave gets stuck at what seems like a narrow hole. If you wobble it top-to-bottom, the wave can pass through as if it were empty space (which it is). If you wobble it diagonally, something interesting happens. Beyond the slit, the rope will behave as if you gave it a (smaller) vertical wobble. Such of your wave as was horizontal gets suppressed, but because there was some motion in the vertical axis there's still something to propagate. That is, the polarizer changes the wave you put in.
You might say, instead of "A polarizer only lets in light of one specific orientation" that "A polarizer only lets out light of one specific orientation." It can satisfy that constraint either by blocking the light or by changing the orientation, and it does both in some mixture based on the input orientation. You can check this with two polarizers at 45 degrees to each other. Since there is only vertically polarized light coming out of the first, if the second could only accept 45-degree light it would be black. Instead it accepts some of the vertical light but lets it through with the new polarization.
Josiah
  • 381
If you mean to say there there are infinite degrees of freedom in the photon polarization, this is not true. As a transverse vector field, electromagnetic waves have only two degrees of freedom. Since the EM wave equation is linear, it obeys the principle of superposition; i.e. any linear combination of solutions is another solution, so while there are infinitely many different polarizations, as you've noted, there are only three linearly independent polarizations for a vector field, one of which corresponds to longitudinal waves—which are forbidden for EM waves—yielding two degrees of freedom.
Now that we've established that there are really only two, rather than infinite, properly distinct (i.e. orthogonal) polarizations (subject to a choice of basis), we can see that it does make sense to say that a polarizer simply blocks one of them and allows the other to pass. Therefore, since unpolarized light contains a mix of both the transmitted and blocked polarizations, some nonzero amount will be let through the polarizer.
Sandejo
  • 5,496
A polariser causes incoming light to decohere into a classical probabalistic distribution of orientations. The polarisation space of light has two (complex) dimensions. A polariser produces very different outcomes for light which is aligned with the polariser, and light which is aligned orthogonally to it. The interaction of the polariser with the light and with the broader environment causes quantum decoherence, which is the phenomenon where a quantum superposition `collapses' into a classical distribution. (Instead of a coin being in a quantum superposition of Heads and Tails, the universe splits into two parallel universe, where in one it's 100% Heads and in the other it's 100% Tails).
Let's assume monochromatic light with a fixed direction, shining straight into the polariser at an orthogonal angle, and an infinitely thin polariser located at $z=0$ for concreteness. The polarisation of any wavepackets of light at $z=0$ can be decomposed into a linear combination of two vectors (with complex components). To anthropomorphise the situation and make it relatable, a polariser takes the polarisation vector, decomposes it into 2 vectors in a particular basis (one that aligns with the polariser orientation, and the orthogonal one) and then throws out the half that's aligned the wrong way.
So you see, rather than thinking about light having just the right polarisation to pass through, you should be thinking about what the length is of the vector that projects onto the polarisation axis. (Slightly rough picture but it conveys the correct mathematical description, without overcomplicating with complex numbers etc.)
We would call something a 'polariser' when we observe that it causes light to behave as described above. At a more technical level, what's happening is that a polariser is a system which causes decoherence of light into the component that aligns with the polariser direction, and the orthogonal direction. Then, classical probability theory takes over: in rough terms, each photon has a % chance to be aligned correctly, and if so then it passes through.
Myridium
  • 1,407
  • 23
