In most mathematics textbooks I have read (see e.g. Axler), the change of basis (COB) matrix has been introduced as a useful computational tool for expressing components of vectors in different bases. In mathematical physics texts (see e.g. Szekeres Chapter 3.6), these are referred to as passive transformations. It is then further stated that we can "interpret" the aforementioned passive transformation as an active transformation if we redefine the COB matrix (which is from one basis $E$ to another $E'$) to actually be the matrix of some linear operator (with respect to the basis $E$ fixed). Of course, the action of that linear operator on $E$ can easily be shown to fully define the operator.
My question is whether there is any deep meaning or reason to this interpretation or not? For two fixed bases $E$ and $E'$ and using the processes mentioned above, there appears to be an isomorphism between the space of passive transformation and the space of linear operators. But so what? Why is this always brought up in the physics literature (even though it never seems to be exploited in any deep way subsequently). Please advise if this question is more appropriate for Math SE.
After further reading, I wonder if perhaps this question is related to the dichotomy mentioned in this question.
EE18
  • 1,321
The subtlety arises from the fact the association between matrices and linear maps is non-canonical and requires a choice of a preferred basis of the vector space.
An active transformation on $V$ is a linear ismorphism $F: V\to V$. Note that this is well-defined without reference to a basis on $V$, and it really maps an element of $V$ to another element.
Choosing a basis $e=(e_1, \dots, e_n)$ of $V$, we can express any vector $v\in V$ uniquely in the form $$v = \sum_{i=1}^n v_i e_i,$$ and the map $v\to (v_1, \dots, v_n)$ gives an isomorphism $\phi_e V \to \mathbb{R}^n$. With respect to this identification, we get a map $$\phi_e \circ F \circ \phi_e^{-1} : \mathbb{R}^n \to \mathbb{R}^n,$$ to which we may associate a square matrix in the usual way.
A passive transformation (COB) is something different. Suppose $e'=(e_1', \dots, e_n')$ is another basis of $V$, then we get a map (and matrix) by $$\phi_{e'} \circ \phi_e^{-1}: \mathbb{R}^n \to \mathbb{R}^n.$$ Essentially what this does is: it takes a representation of a vector with reprect to the basis $e$ as input and gives the representation of the same vector with respect to the other basis $e'$ as output.
So: active transformation really move around a vector in $V$ while passive transformations merely alter how we look at the same vector.
Fraxinian
  • 188
I would argue that it can be very convenient to switch between the two perspectives and thus is actually exploited in physics literature precisely because the mathematics is easier to handle, rather than there being any "deep significance". But being mathematically convenient to handle is a big win and pretty significant in my book :-).
See this paper by Cotler et. al: https://arxiv.org/abs/1702.06142. One of the points of the paper is to start with an abstract Hilbert space $\mathcal{H}$ and Hamiltonian $\hat{H}$ and see if there is a unique, preferred tensor product factorization of $\mathcal{H}$ in which $\hat{H}$ is $k$-local. This criteria and the precise details of the paper are not important for this answer.
What is a tensor product factorization? Well, it is an isomorphism $T: \mathcal{H} \rightarrow \otimes_i\mathcal{H}_i$. So, we are sending our utterly abstract Hilbert space $\mathcal{H}$ into a tensor product factorization of said space. For example, a two spin-1/2 particle system is dimension 4. Thus, the only non-trivial tensor product factorization is $T: \mathcal{H} \rightarrow (\mathcal{H}_1 \cong \mathcal{C}^2) \otimes (\mathcal{H}_2 \cong \mathcal{C}^2)$.
Looks familiar? Well it should. This is basically how we represent choosing a basis for a vector space, i.e., by defining an isomorphism. Thus, changing the tensor product factorization of an abstract vector space can be thought of as a "change of basis" and will sometimes be referred as such. More intuitively, your choice of basis and choice of tensor product factorization both contribute to how your vectors are labelled.
Now, to answer the questions the paper asks, Cotler et. al is interested in looking at these mathematical structures determined by the 3-tuple $(\mathcal{H}, \hat{H}, \mathcal{T})$ where $\mathcal{T}$ is an equivalence class of tensor product factorizations $T$ that are equivalent on common sensical or physical grounds. They want to keep $\mathcal{H}$ and $\hat{H}$ fixed, vary $\mathcal{T}$ and check for each $\mathcal{T}$ if $\hat{H}$ is $k$-local.
Cotler et. al could if they really wanted to stick with this perspective to answer the question. However, it is really confusing to do so. What if we could instead keep $\mathcal{H}$ and $\mathcal{T}$ constant while varying $\hat{H}$? This is much simpler because we can actually fix a tensor product factorization and simply change the Hamiltonian (instead of changing between equivalence classes of isomorphisms)! Well, it turns out that these two perspectives are equivalent and very analogous to the active vs. passive transformation perspectives mentioned in your post.
Silly Goose
  • 4,043
Passive transformation refers to the description of the vector in two different coordinate systems.
Passive transformations describe the point of reference changing.
Active transformation is a transformation of the vector with respect to the same coordinate system.
Active transformations describe the vector changing.
https://en.wikipedia.org/wiki/Active_and_passive_transformation
Active transformation is used when you have your frame of reference for your vector, passive transformation is when your vector is your frame of reference.
I hope that helps.
