I read an article.
When an object is travelling near speed of light, it's mass increase.
The article argues while the inertia increased, that is, the object will be harder to speed up, the gravitational effect doesn't increase. The gravitational effect is always the same with the rest mass of the object.
If that's the case, we should be able to measure that by measuring by how much muon deviate under gravity.
What happened?
As objects travel fast, will they become heavier too?
Will trains traveling fast weight more?
I found something in quora: https://www.quora.com/Do-objects-get-heavier-the-faster-you-move/answer/David-A-Smith-13
In particular, I want to know if David A Smith in the link is simply wrong.
user4951
  • 601
To answer the title of the question, gravitational mass and inertial mass are identical and not just equal. This is the principle of equivalence.
An object's mass (referred to as rest mass) is an invariant. i.e., it does not depend on an observer's frame of reference. Relativistic mass$^1$ i.e., $m=\gamma m_0=\frac{m_0}{\sqrt{1-\frac{v^2}{c^2}}}$ is a deprecated concept. The total energy of an object with rest mass $m_0$ is $$E=\gamma m_0c^2\ \ \ \ \text{with rest energy}\ \ \ \ E_0=m_0c^2$$
As objects travel fast, will they become heavier too? Will trains traveling fast weight more?
The concept of weight and mass are distinct. Mass is measure of inertia (resistance to force) and weight is the force exerted on a mass due to gravitational force. That is, $W=mg$.
But the question is interesting. First note that it is not as simple as saying it has a "relativistic gravitational weight, like $W=\gamma m_0\cdot g$", which is perhaps what you imagined and why you asked the question.
Gravitational fields arise from the stress-energy-momentum tensor $T_{\mu\nu}$ (see the Einstein field equations). So, since the object has an associated stress-energy-momentum due to its relativistic motion, $T_{\mu\nu}$ changes so as to change its gravitational field (increasing its pull on earth) and therefore the earth increases its force on it (it is slightly more complicated than that, but this should be roughly true). So it becomes "heavier" just not the way you thought.
$^1$ Relativistic energy is given by $$E^2=p^2c^2+m_0^2c^4$$ for an object moving with velocity $v$ and has momentum $p=\gamma m_0v$.
joseph h
  • 31,821
Under general relativity they're same and a faster object will warp spacetime more due to having more energy and momentum, hence more gravity. However, a lot of energy is required to produce measurable effect.
