According to Griffiths (Chapter: Electrodynamics and Relativity, Section: Relativistic Electrodynamics)-
We have a string with positive line charge $\lambda$. And on the same string a negative line charge $-\lambda$. The positive charges moving towards right with velocity $v$, and negative charges moving towards left with velocity $v$. So we have a net current to the right, of magnitude $I=2\lambda v$.
If we now look at the setting from a reference frame that is moving towards right, with speed $u$, the velocities of the positive and negative line charges are $$v_{\pm}=\frac{v\mp u}{1\mp vu/c^2}.$$
After this Griffiths has written -
From this new frame the wire seems to carry a net negative charge! In fact, $$\lambda_{\pm}=\pm(\gamma_{\pm})\lambda_0,$$ with $$\gamma_{\pm}=\frac{1}{\sqrt{1-v_{\pm}^2/c^2}},$$ with $\lambda_0$ being the charge density of the +ve line charge in its own rest frame.
My question is --
What is $(\gamma\lambda_0)$? I know $l=l_0 /\gamma$, $t=t_0\gamma$. But if $\lambda=charge/length$, then what is this $(\gamma\lambda)$?
