Generalized versions of Derrick's No-Go Theorem compare spatially scaled, non-trivial, time-independent, finite-energy, classical, field-configurations to exclude the existence of static solitons. (Since we are only considering time-independent field-configurations, there is no kinetic energy $T=0$. Therefore the stationary action principle $\delta S=0$ amounts to minimize the (potential) energy $T+V$. Here $S:=\int \! dt ~L$, and $L:=T-V$. See also this Phys.SE post.)
Let $d$ be the number of spatial dimensions. Assume there exists a stationary field configuration $(\Phi({\bf x}), A_i({\bf x}))$ in temporal gauge $A_0({\bf x})=0$.
Define a 1-parameter family of field configurations is
$$ \Phi^{(\mu)}({\bf x})~=~\Phi(\mu{\bf x}), \tag{4.11} $$
$$ A^{(\mu)a}_i({\bf x})~=~\mu A_i^a(\mu{\bf x}), \qquad i~\in\{1,\ldots,d\}. \tag{4.13} $$
The (potential) energy of the $\mu$-scaled configuration is
$$ e(\mu)~=~\sum_{n\in\{0,2,4\}} \mu^{n-d} E_n\geq 0, \tag{4.22} $$
where we assume that the scale parameter
$$ \tag{A}\mu~\in~]0,\infty[ $$
is strictly positive, and that the energies
$$ E_n~\geq ~0, \qquad n~\in~\{0,2,4\},\tag{B}$$
are non-negative. From this it already follows that the ($\mu$-scaled potential) energy $e:]0,\infty[\to [0,\infty[$ is a non-negative and continuous function, and in particular that it is bounded from below, cf. some of OP's questions.
Case $E_0,E_4>0$ and $d<4$: Then
$$ e(0)~:=~\lim_{\mu\to 0^{+}}e(\mu)~=~\infty~=~\lim_{\mu\to \infty}e(\mu)~=:~e(\infty),\tag{C}$$
so that there must exist an interior$^1$ (relative) minimum, and therefore Derrick's No-Go conclusion does not apply.
Case $d\geq 4$: The function $e$ is monotonically weakly decreasing. [The
word weakly means here that it could be (locally) constant.] The only possibility to have an interior minimum (and therefore evade Derrick's No-Go conclusion) is if $E_0=0=E_2$ and if moreover either
- (i) $d=4$ or
- (ii) $E_4=0$.
The case (i) corresponds to pure 4+1 gauge theory, which indeed has non-trivial static soliton solutions with $E_4>0$. The case (ii) corresponds to vacuum solutions $e\equiv 0$. In both cases (i) and (ii) the function $e$ is a constant function, i.e. independent of the scale parameter $\mu$.
Case $E_0=0=E_2$: The function $e$ is monotonic. The only possibility to have an interior minimum (and therefore evade Derrick's No-Go conclusion) is, if
- (i) $d=4$, or if
- (ii) $E_4=0$,
i.e. we are back in the previous case (2).
References:
N. Manton and P.M. Sutcliffe, Topological Solitons, 2004, Section 4.2.
S. Coleman, Aspects of symmetry, 1985. Note that Sidney calls solitons for lumps.
R. Rajaraman, Solitons and Instantons: An Introduction to Solitons and Instantons in Quantum Field Theory, 1987.
$^1$ An interior minimum point $\mu$ means that $\mu$ is different from the boundary $0$ and $\infty$.
