There is an observer at ($r,\theta, \phi$) outside of the Schwarzschild blackhole. A beacon is falling into the black hole along $r$ coordinates of the metric and is emitting radiation. At $r_{em}$, it emits a photon of frequency $\omega_{em}$, what will be the frequency of the light which is observed by the observer (assuming only radial trajectories)? In Sean Caroll, Chapter-5 eq. (5.100), he defines the frequency of the photon to be $$\omega = -g_{\mu \nu} U^{\mu} \frac{dx^{\nu}}{d\lambda}.\tag{5.100}$$However, I am not sure how he got this expression? Is there some intuitive way to get the same expression.
I was thinking about this and it seems that the $\omega$ would change according to the time dilation factor because of the curvature components of the metric.
Please correct me if I am wrong and kindly guide me.
To answer your question, we need a few calculations that I will try to make short.
Using the Schwarzschild metrics, and considering that the photon is emitted in a radial direction, the energy of the photon measured by a static observer is: $$ E = -\frac{c}{\sqrt{1-\frac{2GM}{c^2r}}}\vec{ξ(0)}.\vec{p} $$ with $ r $ radial coordinate, $ \vec{ξ(0)} $ vector of Killing and $ \vec{p} $ four-momentum of the photon.
Along a light geodesics, the quantity $ \vec{ξ(0)}.\vec{p} $ is maintained, then you can write for the emission and for the reception of the photon $ (\vec{ξ(0)}.\vec{p})_{em}=(\vec{ξ(0)}.\vec{p})_{rec} $ which means: $$ E_{rec}=\sqrt{\frac{1-\frac{2GM}{c^2r_{em}}}{1-\frac{2GM}{c^2r_{rec}}}}E_{em}\ \ \ \ \ [1] $$
In addition, because $ E=\frac{hc}{\lambda} $ with $ \lambda $ wave length of the photon, you have with $ \omega $ frequency of the photon: $$ \frac{E_{rec}}{E_{em}}=\frac{\lambda_{em}}{\lambda_{rec}}=\frac{\omega_{rec}}{\omega_{em}} $$ which gives according to $ [1] $: $$ \omega_{rec}=\sqrt{\frac{1-\frac{2GM}{c^2r_{em}}}{1-\frac{2GM}{c^2r_{rec}}}}\omega_{em} $$
This shows that the reception frequency of the photon does indeed change with respect to its emission frequency.
Hoping to have answered your question,
Best regards.
The RHS of eq. (5.100) is the RHS of $$E~=~-p_{\mu}U^{\mu},\tag{3.63}$$ where the affine parameter $\lambda\to a\lambda+b$ can be scaled such that $$p^{\mu}~=~\frac{dx^{\mu}}{d\lambda}\tag{3.62}$$ is the 4-momentum of the photon. Here Carroll is using units with $\hbar=1$ so that $E=\hbar\omega=\omega.$
In eq. (3.89) and in a paragraph between eqs. (5.62-63) Carroll argues that the scalar invariant $\omega$ can be thought of as the observed frequency of the photon if we use local initial/normal coordinates $\left. g_{\mu\nu}\right|_p=\eta_{\mu\nu}$ for a static observer $U^{\mu}=(1,0,0,0)$.
