Gauss Law 2D
So I went through the Khan Academy tutorial on divergence and flux calculations for an area C encircled by a parametric function $s(t)$.
Flux
Here $C$ will be a circle with a radius $r$, centered by a point charge $+q$. $F$ will be the electric field vector $E(s(t))$, and $n$ will be the normal vector for the point $s(t)$. As electric field lines permeate outwards linearly, they are parallel with the normal vector. Hence $|E|\times|n|\times cos(\theta) = |E|\times1\times1 = |E| = \frac{q}{4\pi\epsilon_0r^2}$
For sake of calculating $ds$, we will still need a definition of $s(t) = [rcos(t), rsin(t)]$.
$$s'(t) = [-rsin(t), rcos(t)]$$ $$ds = |s'(t)|dt = r*dt$$
So let's bring them all together,
$$\int \frac{q}{4\pi\epsilon_0r^2}\times r*dt =$$ $$\int \frac{q}{4\pi\epsilon_0r}\times dt =$$ $$\frac{q}{4\pi\epsilon_0r} \int dt$$
We have to take the integral for the time interval $(0, 2\pi)$, a full period of $s(t)$. This will give us the following end result:
$$\frac{q}{4\pi\epsilon_0r} \times 2\pi = \frac{q}{2\epsilon_0r}$$
It is okay, except that annoying $r$ at below. What mistake I did here? I can't see. Please help. Also is experimenting with stuff like good for a student? Or should I just stick to my curriculum?
