We have two beams side-by-side: an electron beam and a proton beam. I understand that there will be a force of attraction between them (opposite charges).
But can this force turn repulsive if:
  1. the beams are traveling in different speeds (in the same direction)
  2. the beams are traveling in opposite direction
I saw some similar questions asked already but couldn't find the speed connection anywhere.
Janaaaa
  • 247
If you are talking about beams, then you can assimilate them as uniformly charged lines moving at their respective velocities. For simplicity, I’ll assume the beams to be parallel. You won’t need relativity, but only basic electromagnetism.
Say the proton (resp. electron) beam has linear charge density $\lambda_+>0$ (resp. $\lambda_-<0$) moving at velocity $v_+$ (resp. $v_-$). Note that the velocity is signed so $v_+v_->0$ when they go in the same direction. The beams therefore carry currents $I_\pm=\lambda_\pm v_\pm$. All the defined quantities are measured with respect to the lab.
Each beam thus generates the EM fields: $$ E=\frac{\lambda_\pm}{2\pi \epsilon_0 r} \\ B=\frac{\mu_0 I_\pm}{2\pi r} \\ $$ So let $d$ be the distance between the two beams you get the electric and magnetic forces (per unit length) to be: $$ F_E=\frac{\lambda_+\lambda_-}{2\pi \epsilon_0 d} \\ F_B=\frac{\mu_0 I_+I_-}{2\pi d} $$ As expected, the electric force is always attractive since they are oppositely charged. However, the magnetic force is attractive when they move in opposite directions and repulsive when they don’t.
You can calculate the ratio of the forces to be: $$ \frac{F_B}{F_E} =\frac{v_+v_-}{c^2} $$ In the vacuum, speeds are smaller than the speed of light, the magnetic force will never compensate the electric force. However in refractive media, the speed of light can be effectively reduced, and it is therefore physically possible for the magnetic force to overcome the electric force.
Hope this helps.
LPZ
  • 17,715
  • 36
Simply put: no.
There is a sense, which I think you've found already, in which magnetic forces arise from changes to the charge density produced by Lorentz transformations between the frames of different moving charges. (If you haven't read about it, or you're not fully confident about how and why it's a thing, I recommend the relevant chapter in Purcell's EM textbook.)
And, since magnetic forces can be repulsive, it is indeed a natural question to ask whether they can become strong enough to overcome the electrostatic repulsion between two charges.
... and the answer to that is: no.
The reason is that, if you have a beam of protons moving relative to a beam of electrons, you can always place your analysis in the rest frame of the proton beam (or the electron beam; you'll reach the same conclusions). There, the protons are at rest, and the electrons are moving with some velocity. The frame transformation will induce changes to the density of charge in the electron beam, mostly due to length contraction (or the elimination of it, for co-moving beams). But if the two beams consist of charge of only one sign, then the total charge density can never change sign, no matter how creative you get with relativistic length contraction.
And, moreover, magnetic effects don't matter on this new frame. Sure, the electrons are moving, and as such they produce a magnetic field, but the protons are stationary and as such they experience no magnetic Lorentz force at all.
So the interaction will always be between protons and electrons, and it will always be attractive.
Having said this, the analysis above should raise an obvious question: how come magnetic forces between current-carrying wires can be repulsive, then? The main reason is that most current-carrying conductors consist of charges of both signs, moving at different velocities. (Normally, a stationary lattice of ions combined with a slowly moving sea of electrons, but all sorts of combinations are possible or at least conceivable.) And if you have charges of both signs in the wire, then it becomes possible to get creative with Lorentz length contraction to make the total charge on the wire positive, or negative, or zero, because the charges of different signs are moving differently, and as such you can affect them differently with the length contraction.
Emilio Pisanty
  • 137,480
