I am a high school student and I am very confused about what's actually happening at the microscopic scale in an ideal solution when it's boiling? Boiling as I understand at microscopic level is- suppose we are heating water at one atmospheric pressure, it's temperature will rise but only surface molecules will have enough energy to escape because the bubble formed didn't have enough to pressure inside them as compared to atmospheric pressure , so they collapse.
But as the temperature reaches 100 degrees Celsius the pressure inside the bubble will be sufficient enough to overcome the atmosphere pressure and it will rise and pops up at the surface, via this explanation we can Clearly see if we decrease the atmospheric pressure, the pressure which the bubble need inside them to not collapse will be less so the boiling point will be less.
But what matters here is the pressure inside those bubbles and not vapor pressure (which is the pressure exerted by liquid above it's surface at any temperature of its in equilibrium) . So why bubbles can't form inside the bulk at a point where the vapor pressure of liquid is less than atmospheric pressure? I mean there should be some high energy molecules in the bulk which should be able to form bubbles which can counter their surrounding pressure and rise, but why it doesn't happen? Why we put a condition that there has to be overall 0 pressure on liquid for bubbles to form?
Shyam
  • 49
Shorter answer: A higher temperature is needed to boil impure liquid water because its water concentration is less than 100%; therefore, we need to apply a greater driving force to attain the 100% water concentration of water vapor. (The same effect occurs with freezing impure liquid water into pure ice; some undercooling below 0°C is required. In this sense, impure liquid water seems to be a more stable phase than pure liquid water.)
Longer answer: Let's first address a misconception:
So why does it need more energy know for bubbles to form inside the water?
It doesn't; the latent heat of vaporization of water actually decreases slightly with increasing temperature. But it certainly does take a higher temperature to boil the water with the solute. Why?
Broadly, we seek a way to determine what phase of matter is the most stable, or—even better—a general rule for how matter moves and transforms.
That rule is energy minimization, a consequence of the Second Law of Thermodynamics. (In familiar examples, stretched or compressed springs holding strain energy tend to relax when the load is removed; liquid surfaces holding surface energy tend to curve to reduce their surface area; suspended objects with gravitational potential energy tend to fall when released.)
The relevant energy here when we're controlling temperatures and pressures is the Gibbs free energy. An open liquid–vapor system is at equilibrium when its Gibbs free energy is minimized.
Considering individual phases, the partial molar Gibbs free energy is called the chemical potential. Using this new term, matter moves to where the chemical potential is lowest.
The chemical potential of a substances decreases with increasing temperature, and the rate of decrease is just the entropy of the substance. The gas phase has a higher entropy than the liquid phase, and so the curve of the chemical potential or Gibbs free energy is always steeper for the gas phase:
Again, the lowest curve corresponds to the most stable equilibrium phase at that temperature. The Gibbs free energy decreases with stronger bonding (as with solids) but also with more configurations (as with gases), and the latter tendency wins out with increasing temperature. That's why solids melt and liquids boil with increasing temperature.
The chemical potential is related to a quantity called the activity. The activity of pure condensed matter is 1; the activity of impure condensed matter is lower. The activity of a component in an ideal mixture is just its concentration.
This gives us a framework for understanding boiling of pure and impure water: With increasing temperature, the Gibbs free energy decreases for both the liquid and the gas phases, but the decrease is stronger for the gas phase. At 100°C, the Gibbs free energy or chemical potential of liquid and gaseous water is identical. This corresponds to a vapor pressure of 1 atm, enough for nucleated vapor bubbles to begin to push liquid water out of the way.
If the water is impure, then its concentration is less than 100%, and its Gibbs free energy or chemical potential is therefore lower. But the impurity is nonvolatile—meaning it doesn't evaporate—and so the vapor phase is still 100% water, and its chemical potential remains unchanged. The mismatch favors the liquid state! Its curve is now lower, and so a higher temperature is required for the curve crossover associated with boiling. The effect scales up with increasing solute concentration because the water (solvent) concentration continues to decrease.
On a molecular level, you could imagine fewer water molecules per unit surface area of the impure liquid (because the solute molecules occupy some space), and so the rate of evaporation is lower. However, the gas phase contains the same concentration of water, and so condensation occurs at the same rate regardless of the liquid water's purity. This is another way to look at the shifted equilibrium: If evaporation is suppressed whereas condensation is unaltered, the liquid phase is favored somewhat, and we need to move to a higher temperature to reach the rate of evaporation that corresponds to boiling. We need to compensate for the solute reducing the water's concentration.
Does this all make sense?
When a bubble is forming in a boiling liquid, it's filled with vapor from that liquid. The bubble is in direct contact with the liquid, allowing molecules to rapidly move between the liquid and vapor phases.
Over time, the rate at which molecules evaporate from the liquid into the bubble and the rate at which they condense back into the liquid become equal. This is a state of dynamic equilibrium.
At equilibrium, the pressure of the vapor inside the bubble (the internal pressure) is effectively the same as the vapor pressure above the liquid. This is because the same process of evaporation and condensation is happening both inside the bubble and at the liquid's surface.
