Seeing the equation,
\begin{equation*} (\hat{A} -\lambda)G_\lambda (\mathbf{x},\mathbf{y})=\delta^{(3)}(\mathbf{x}-\mathbf{y}) \tag{1} \end{equation*}
in the answer
What is different between resolvent and green function
prompts me to ask a question about a comment, found in Byron and Fuller$^1$, on pg 533
The comment is
the Green’s function of the operator $(~I - \lambda A~)$ is $(~I+\lambda R_A~)$
Reference 1, continues
this may be seen by looking at Eq(9.23)
Now. (9.23) is
\begin{equation*} (~I - \lambda A~)^{-1}=(~I+\lambda R_A~) \tag{9.23} \end{equation*}
with $I$ the unit operator, $A$ and $R_A$ operators, the latter the resolvent of $A$.
It appears that some liberty is being taken here, because $(~I+\lambda R_A~)$ is an operator, not a function.
My question is: Might the comment, from Byron and Fuller, be intended to bring to mind, that \begin{equation*} (~I - \lambda A~)~(~I - \lambda A~)^{-1}=1 \end{equation*} which means \begin{equation*} (~I - \lambda A~)~(~I + \lambda R_A~)=1 \end{equation*} can be thought of as analogous to (1)?
Reference:
1, Frederick W. Byron, Jr. and Robert W. Fuller, Mathematics of Classical and Quantum Physics, Dover 1992
Yes, it is the same formula, even though people are loose with notations and conventions.
Your formula (1) is predicated on integral kernels, that is, operator multiplication is integration of a "function" kernel with the function argument. So $\hat G_x ~\psi(x) \equiv \int\!\! dy ~ G(x,y)\psi(y)$, by virtue of $\langle x|\hat G |\psi\rangle= \int\!\! dy ~ \langle x|\hat G |y\rangle \langle y|\psi\rangle $.
Given that, you may think of (1) as $$ (\hat A -\lambda I)~ (\hat A -\lambda I)^{-1}= I. $$
The resolvent is normally defined as $$ \hat R (\lambda; \hat A) = (\hat A -\lambda I)^{-1}. $$ For large eigenvalues λ, you might think of it as $(-1/\lambda)(I+\hat A/\lambda+ \hat A^2/\lambda^2+...)$. Hilbert's original introduction of this resolvent was to explore the set of its singularities as the spectrum of operators such as $\hat A$.
Now, B&F (9.23) is the same formula, having suppressed the operator carets; except for $\mu = 1/\lambda$, and an overall minus sign introduction, $$ (I- \mu A)~ (I-\mu A)^{-1}= I. \tag{9.23} $$ However, now (9.23) is defining its resolvent slightly differently than the mainstream convention, namely as $$ R_A= A(I-\mu A)^{-1}= A+\mu A^2+\mu^2 A^3+..., $$ so evidently still a function of A and μ.
It follows that $$ (I+\mu R_A) (I-\mu A)=(I +\mu A(I-\mu A)^{-1})(I-\mu A) =I. $$
The various notational options are predicated on whether one is focussing on Neumann series of Fredholm inhomogeneous equations as in B&F, or elegant contour integrations picking up the singularities of the resolvent.
Cosmas Zachos
  • 67,623
I’d like to add some details about the answer of Cosmos Zachos, dated 25th Feb. 2023. These details, might make his answer be useful to more people.
Details: 1
On the part that says
you may think of (1) as $(\hat A -\lambda I)~ (\hat A -\lambda I)^{-1}= I~$
When learning about equations involving “bare” delta functions, such as (1), I picked up two ideas
  1. Such an equation, did not make complete sense
  2. It was “unfinished”, without putting the delta function inside some integral
If you turn (1) into complete sense by integrating both sides with a function $f(\mathbf{y} )$, you obtain
\begin{equation*} \int d\mathbf{y} ~(\hat{A} -\lambda) G_\lambda (\mathbf{x},\mathbf{y}) f(\mathbf{y} )= \int d\mathbf{y} \delta^{(3)}(\mathbf{x}-\mathbf{y}) f(\mathbf{y}) \end{equation*}
Interchanging the order of $\int$ and $(\hat{A} -\lambda)$ \begin{equation*} (\hat{A} -\lambda) \int~ d\mathbf{y} G_\lambda (\mathbf{x},\mathbf{y}) f(\mathbf{y} )= \int d\mathbf{y} \delta^{(3)}(\mathbf{x}-\mathbf{y}) f(\mathbf{y}) =f(\mathbf{x}) \end{equation*}
Defining, $G_x$ by
\begin{equation*} G_x~f(\mathbf{x}) = \int~ d\mathbf{y} G_\lambda (\mathbf{x},\mathbf{y}) f(\mathbf{y} ) \end{equation*} we can say, for any of our $f(\mathbf{x})$, the integrated form of (1) is the same as
\begin{equation*} (\hat{A} -\lambda)G_x~f(\mathbf{x}) =~f(\mathbf{x}) \end{equation*}
This means that \begin{equation*} (\hat{A} -\lambda)G_x =I \end{equation*} and \begin{equation*} G_x=(\hat{A} -\lambda)^{-1} \end{equation*} Hence our integrated form of (1), " the complete sense form of (1) " , is equivalent to the operator equality \begin{equation*} (\hat{A} -\lambda) (\hat{A} -\lambda)^{-1}=I \end{equation*}
Details:2
The answer starts with
This opening phrasing, takes quite some justification. It is saying that \begin{equation*} (~I - \lambda A~)~(~I - \lambda A~)^{-1}=I~~~\tag{2} \end{equation*} is the same thing as
Now, in ‘Details:1’, it is shown that the complete sense version of (1), can be thought of as the same as
\begin{equation*} (\hat A -\lambda I)~ (\hat A -\lambda I)^{-1}= I~~\tag{3} \end{equation*}
Hence, we show that (2) is the same as (1), if we show that the LHS’s of (2) and (3), are the same expression.
NB: I use the rule that for operators , including multiplication by a scalar, $(BC)^{-1}=C^{-1}B^{-1}$.
For the LHS of (2) we have
\begin{equation*} (~I - \lambda A~)~(~I - \lambda A~)^{-1}= (-1)(~ \lambda A-I~) (~-1 (~ \lambda A-I~)~)^{-1} \end{equation*}
\begin{equation*} = (~-1~)(~ \lambda A-I~) (~ \lambda A-I~)^{-1}~(~-1 ~) \end{equation*}
\begin{equation*} =\lambda~\left(~A-\frac{ I }{\lambda} \right) \left( \lambda~(~A-\frac{ I }{\lambda})\right)^{-1} \end{equation*}
\begin{equation*} =\lambda~\left(~A-\frac{ I }{\lambda} \right) \left( ~A-\frac{ I }{\lambda} \right)^{-1} \frac{1}{\lambda} \end{equation*}
Cancel the $\lambda$’s and put $\mu = 1/\lambda$ \begin{equation*} =(~A-\mu I ) (~A-\mu I ) ^{-1} \end{equation*}
Introduce a new $\lambda$ by $\lambda= \mu$, this finishes off the transformation of the LHS of (2) into the LHS of (3).
That is, we can think of (2), as the same as the complete sense form of (1).
This justifies the start of the answer.
