"The second is the duration of 9192631770 periods of the radiation corresponding to the transition between the two hyperfine levels of the ground state of the caesium 133 atom."
This implies that subatomic processes are happening at a rate that only appears constant. If we move the atomic clock away from the earth (away from gravity), the rate at which subatomic processes take place changes.
Is this incorrect? And can this be extended to things such as the speed of an electron around a nucleus?
