On every source and in every example, it seems that sympathetic vibrations are quite directly linked to or are the same as resonance.
The classic example of sympathetic vibrations is of two similar tuning forks (same frequency). When one of these tuning forks is set into vibration and brought close to the other at rest, the latter starts to vibrate. Here, air is forced into vibration at the same frequency as itself by the first tuning fork, and these vibrations carry to the second tuning fork which vibrates readily (resonance).
My textbook, however, defines sympathetic vibrations as -
The amplitude of forced vibrations of a body does not remain constant due to the presence of damping forces of the surrounding medium. However, it is possible to keep the amplitude of vibrations constant by applying an external periodic force such that the external periodic force compensates for the loss of energy in each vibration due to the damping forces. The vibrations of the body are then called sympathetic vibrations.
I am aware that resonance means that bodies having natural frequencies or higher harmonics similar to the frequency of external periodic forces acting on them will vibrate readily with heightened amplitude.
If I'm understanding correctly:
Vibrations can carry from an external periodic force to a body even if the body does not resonate with the external force, the amplitude in such a case is small(compared to resonance) and the body vibrates with the frequency of the driving force and not its natural frequency.
Even in such a case - It is possible to keep the amplitude of vibrations of the body constant by applying an external periodic force which does not resonate with the body such that the external periodic force compensates for the loss of energy in each vibration due to the damping forces.
So if that can be done without resonance being involved, why are sympathetic vibrations referred to with examples of resonance everywhere? Is it that the textbook I'm referring to is entirely wrong or not specific? An intuitive answer would be highly appreciated.
Kayen Jain
  • 47
I think the distinction is that the driving source may be vibrating itself, or it may be simply providing a periodic force. One or the other is essential if the vibration is to be sustained despite damping.
The classic example is pushing a kid on a playground swing. If you push every time at the same point in the swing, small pushes can make the kid swing high. But your pushing is not a vibration, even though it is a periodic force. So I would not call that sympathetic vibration.
However, if you were to place a (very large) loudspeaker behind the kid and play a sine wive through it at the right (very low) frequency, you could conceivably get the kid to swing via sympathetic vibration.
Both of the phenomena are resonance, but only one is sympathetic vibration.
Rich006
  • 719
