I'm wondering if $\phi^5$ is a descendant in $\phi^4$-theory in $d = 4 - \epsilon$ at the conformal Wilson-Fisher fixed point, where the coupling constant is $\lambda$. The e.o.m. tells us that $\phi^3$ is a total derivative (and therefore also a descendant) of $\phi$ (let us not care about the numerical factors, and suppress the spacetime indices on the derivatives that is summed over) \begin{equation} \partial^2\phi \sim \lambda\phi^3 \ . \end{equation} Now regarding $\phi^5$, we find from $\partial^2\phi^3$ and the e.o.m. that $\phi(\partial\phi)^2$ is related to $\phi^5$ \begin{equation} \partial^2\phi^3 \sim \phi(\partial\phi)^2 + \lambda\phi^5 \quad\text{or}\quad \phi(\partial\phi)^2 \sim \lambda\phi^5 + \partial^2\phi^3 \ . \end{equation} Since $\partial^2\phi^3$ is a descendant (which in turn is a descendant of $\phi$ due to the e.o.m.), we should only treat either $\phi^5$ or $\phi(\partial\phi)^2$ as a primary.
However, if we now study $\partial^4\phi$ using the equation above, we find \begin{equation} \partial^4\phi \sim \lambda^2\phi^5 + \lambda\partial^2\phi^3 \quad\text{or}\quad \lambda^2\phi^5 \sim \lambda\partial^2\phi^3 + \partial^4\phi \ . \end{equation} From this equation it looks like $\phi^5$ is a descendant of $\phi$. Is this correct?
If so, we can use the reasoning for $\phi^6$ (by studying $\partial^2\phi^4$ and $\partial^4\phi^2$) and find that $\phi^6$ is a descendant.
If my reasoning is incorrect, which ones are the primaries with scaling dimension $\Delta = 5 + \mathcal{O}(\epsilon)$?
A.Dunder
  • 421
Your last equation does not follow from the others.
The combinations of fields and derivatives which give primary operators in Wilson Fisher are almost the same as those for the free theory. Due to multiplet recombination, there is one exception at spin zero ($\phi^3$) and one exception at each odd spin $\geq 5$. If $\phi^5$ were to be eaten, the free theory would need to have a primary at the unitarity bound of dimension $5 - n$ which is killed by $n$ derivatives and not by any smaller number of derivatives. There is no such operator so $\phi^5$ stays primary.
Connor Behan
  • 10,659
